  <title>R-pod Owners Forum : Yellow Stains/Streaks From Decal Adhesive</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : Yellow Stains/Streaks From Decal Adhesive</description>
  <pubDate>Fri, 23 Oct 2026 10:20:48 +0000</pubDate>
  <lastBuildDate>Sat, 05 May 2018 20:29:07 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11475</WebWizForums:feedURL>
   <title>Yellow Stains/Streaks From Decal Adhesive : Thanks jato!I&amp;#039;ll take a look...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108786#108786</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7439" rel="nofollow">DavMar</a><br /><strong>Subject:</strong> 11475<br /><strong>Posted:</strong> 05 May 2018 at 8:29pm<br /><br />Thanks jato!<br><br>I'll take a look and see if I can find this Blue Magic Road Tar &amp; Bug Gel st my local FLAP (friendly neighborhood auto parts) of course if you want to come South with your chainsaw I'd be most appreciative! <img src="https://www.rpod-owners.com/smileys/smiley2.gif" border="0" alt="Wink" title="Wink" /><br>]]>
   <pubDate>Sat, 05 May 2018 20:29:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108786#108786</guid>
   <title>Yellow Stains/Streaks From Decal Adhesive : Maybe hire a neighbor with a chain...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108785#108785</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 11475<br /><strong>Posted:</strong> 05 May 2018 at 8:24pm<br /><br />Maybe hire a neighbor with a chain saw and&nbsp; . . . .? Anyway I have used a product by Blue Magic called "Road Tar &amp; Bug Gel that works fairly well and one better than that as one time we were under a white pine that had terrible sap drip all over the roof of our pod as well as our Explorer is produced by Guardsman called "Goof Off" it worked well but also took a bit of elbow grease to get the tar off.&nbsp; Put product on rag and rub over the spot.&nbsp; Would also highly recommend a good wax job after doing this to put a coating over the gel coat.&nbsp; I have used a product by MeGuiars called Ultimate liquid wax, leaves the finish baby butt smooth.<br>]]>
   <pubDate>Sat, 05 May 2018 20:24:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108785#108785</guid>
   <title>Yellow Stains/Streaks From Decal Adhesive :   Originally posted by jatoWe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108784#108784</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7439" rel="nofollow">DavMar</a><br /><strong>Subject:</strong> 11475<br /><strong>Posted:</strong> 05 May 2018 at 7:53pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by jato</strong></em><br /><br />We have had good success using a clay bar (fine grit), because it is so fine it does take a bit of elbow grease but have never damaged the finish by using it.&nbsp; Our 177 is just over 7 years old, still looks great.</td></tr></table><br><br>Never thought of a clay bar but that's a good suggestion Leo +1<br><br>Though here is a tough one I'd like to find an answer for as to cleaning the outside of my Pod. Where it parks there is a Maple tree that partly shades it and in turn leaves little black sap specks all over the Pod. Since my tree hugging wife won't allow me to put chain saw to tree does anyone have a suggestion for a quick and easy product I can use to remove this sap spots????<br>]]>
   <pubDate>Sat, 05 May 2018 19:53:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108784#108784</guid>
   <title>Yellow Stains/Streaks From Decal Adhesive : We have had good success using...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108236#108236</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 11475<br /><strong>Posted:</strong> 26 Apr 2018 at 5:06pm<br /><br />We have had good success using a clay bar (fine grit), because it is so fine it does take a bit of elbow grease but have never damaged the finish by using it.&nbsp; Our 177 is just over 7 years old, still looks great.]]>
   <pubDate>Thu, 26 Apr 2018 17:06:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108236#108236</guid>
   <title>Yellow Stains/Streaks From Decal Adhesive :   MTB you can damage the gelcoat...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108215#108215</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 11475<br /><strong>Posted:</strong> 26 Apr 2018 at 2:16pm<br /><br /><div>MTB you can damage the gelcoat with abrasive cleansers, like Comet. &nbsp;It works really well getting stuff off because it takes off some of the gelcoat with it and you will find that the sheen on the gelcoat will be gone. &nbsp;Use a boat cleaner or soft rubbing compound to clean stubborn stains, then wax over what you cleaned or the stains will quickly return. &nbsp;There are many products specifically designed to clean fiberglass surfaces in RV shops or marine supply stores.</div>]]>
   <pubDate>Thu, 26 Apr 2018 14:16:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108215#108215</guid>
   <title>Yellow Stains/Streaks From Decal Adhesive : My husband I and noticed yellow...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108206#108206</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8265" rel="nofollow">MTB Couple</a><br /><strong>Subject:</strong> 11475<br /><strong>Posted:</strong> 26 Apr 2018 at 11:25am<br /><br />My husband I and noticed yellow stains/streaks on our pod that ran down from the decals. We figured perhaps too much adhesive had been used when applying the decals, so we tried Goof Off, but that didn't work. I decided to try a little bit of Comet with bleach. I tested it on a small inconspicuous spot and it worked! I created a thick paste by mixing the Comet with a little water and I used a medium bristled brush to apply the paste in a circular motion. It didn't require a lot of elbow grease at all, the stains just came right off.&nbsp;<div><br></div><div>I hope this can help someone else! :-)&nbsp;</div>]]>
   <pubDate>Thu, 26 Apr 2018 11:25:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11475&amp;PID=108206#108206</guid>
