  <title>R-pod Owners Forum : Need new converter</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Need new converter</description>
  <pubDate>Thu, 29 Oct 2026 21:12:48 +0000</pubDate>
  <lastBuildDate>Wed, 25 Apr 2018 21:28:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11473</WebWizForums:feedURL>
   <title>Need new converter : I had one go bad. I ordered a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108188#108188</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 11473<br /><strong>Posted:</strong> 25 Apr 2018 at 9:28pm<br /><br />I had one go bad. I ordered a replacement on Amazon. Then I went on the WFCO site and got the information on how to send it in and it was replaced under warranty. I now have a spare in the box in case it were to happen again. I don't think it is the brand as such. I think they got a bad batch of some components which made for problems. It is likely that newer ones will not have the same failure issues.<br>This link is <a href="http://wfcoelectr&#111;nics.com/warranty-returns/" target="_blank">WFCO's Warranty Returns</a> page. You will find a testing checklist as well as instructions on how to request an RGA number on the Warranty Information Fax Sheet.<br>]]>
   <pubDate>Wed, 25 Apr 2018 21:28:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108188#108188</guid>
   <title>Need new converter : I just changed our converter about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108185#108185</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 11473<br /><strong>Posted:</strong> 25 Apr 2018 at 8:22pm<br /><br />I just changed our converter about a month ago using the WFCO replacement. &nbsp;The old one lasted 9 years. &nbsp;I got it on Amazon and it came in 2 days. &nbsp;It took about 20 minutes to change. &nbsp;It comes with a 2 year guarantee. &nbsp;So far it's working fine.<div><br></div><div>But, after changing my converter, I saw a number of posts saying that some have had issues with this brand and recommend other makes. &nbsp;If I ever have to replace it again, I'll certainly check out the ones such as recommended by Furpod.</div>]]>
   <pubDate>Wed, 25 Apr 2018 20:22:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108185#108185</guid>
   <title>Need new converter : +1 </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108182#108182</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11473<br /><strong>Posted:</strong> 25 Apr 2018 at 7:28pm<br /><br />+1]]>
   <pubDate>Wed, 25 Apr 2018 19:28:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108182#108182</guid>
   <title>Need new converter : If I was changing on my dime,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108180#108180</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 11473<br /><strong>Posted:</strong> 25 Apr 2018 at 7:25pm<br /><br />If I was changing on my dime, I would buy the much better, <a href="http://www.progressivedyn.com/rv/power-c&#111;nverters/inteli-power-4600-series/" target="_blank">progressive dynamics replacement</a>.&nbsp;]]>
   <pubDate>Wed, 25 Apr 2018 19:25:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108180#108180</guid>
   <title>Need new converter : Is it under warranty?  These converters...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108172#108172</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11473<br /><strong>Posted:</strong> 25 Apr 2018 at 6:21pm<br /><br />Is it under warranty?  These converters are readily available, and are common.  You can buy one and contact WFCO about repair.  Then you will have a spare.]]>
   <pubDate>Wed, 25 Apr 2018 18:21:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108172#108172</guid>
   <title>Need new converter : Thew converter in my RPod 179...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108170#108170</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6293" rel="nofollow">rlantram</a><br /><strong>Subject:</strong> 11473<br /><strong>Posted:</strong> 25 Apr 2018 at 5:44pm<br /><br />Thew converter in my RPod 179 is kaput.&nbsp; No charging when on shore power.&nbsp; No fan running.&nbsp; I photographed the barcode and called Camping World.&nbsp; They did not know what I was talking about.&nbsp; Wanted me to bring the trailer in.&nbsp; I just want to buy the part.&nbsp; Tried to get the part through Forest River.&nbsp; They wish me to pay $5 to talk to a Forest River Technician.&nbsp; Why is this so hard?&nbsp; How do I get my part?<div><br></div>]]>
   <pubDate>Wed, 25 Apr 2018 17:44:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11473&amp;PID=108170#108170</guid>
