  <title>R-pod Owners Forum : Potential R-Pod Owner with a Question</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Potential R-Pod Owner with a Question</description>
  <pubDate>Thu, 24 Sep 2026 15:03:38 +0000</pubDate>
  <lastBuildDate>Tue, 03 Apr 2018 17:18:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11350</WebWizForums:feedURL>
   <title>Potential R-Pod Owner with a Question : Thank you. I&amp;#039;ll pass that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106822#106822</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8181" rel="nofollow">Mimo</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 5:18pm<br /><br />Thank you.&nbsp; I'll pass that on to the husband.<div>Mimo</div>]]>
   <pubDate>Tue, 03 Apr 2018 17:18:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106822#106822</guid>
   <title>Potential R-Pod Owner with a Question : That&amp;#039;s the low spot.  I had...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106821#106821</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 5:14pm<br /><br />That's the low spot.  I had a Class C that got caught in a Nor'easter in NJ that caused delamination, insurance didn't cover and I lost a ton when I let it go.  When they get soft the lamination is gone.  You have to remove the bad spot and rebuild the area.  Not sure what your capability is but could easily cost you a year of camping.]]>
   <pubDate>Tue, 03 Apr 2018 17:14:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106821#106821</guid>
   <title>Potential R-Pod Owner with a Question : Thanks mcarter. It&amp;#039;s just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106820#106820</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8181" rel="nofollow">Mimo</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 5:07pm<br /><br />Thanks <b>mcarter</b>.&nbsp; It's just one spot and we are trying to figure it out.&nbsp; Not the price is not really low.&nbsp; Up here an R-Pod is less common than a visitor from outer space.&nbsp; But you may well be the voice of reason here.<div><br></div><div>Monika</div>]]>
   <pubDate>Tue, 03 Apr 2018 17:07:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106820#106820</guid>
   <title>Potential R-Pod Owner with a Question : In the process of doing so, Leo...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106819#106819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8181" rel="nofollow">Mimo</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 5:05pm<br /><br />In the process of doing so, Leo B.&nbsp; Thank you.]]>
   <pubDate>Tue, 03 Apr 2018 17:05:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106819#106819</guid>
   <title>Potential R-Pod Owner with a Question : Personally I would not buy and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106818#106818</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 5:04pm<br /><br />Personally I would not buy and RV with soft floors.  The repair can be extensive.  Leaks and water intrusion are a killer to RVs, move on.  If the price is really low and you have the time to fix, I say it's a project.]]>
   <pubDate>Tue, 03 Apr 2018 17:04:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106818#106818</guid>
   <title>Potential R-Pod Owner with a Question : If you go to the top corner of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106817#106817</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 5:03pm<br /><br />If you go to the top corner of the page , you will see a search window. If you type in your topic there, it will search all the past post in the forum and should give you all the post that are on that topic. &nbsp;]]>
   <pubDate>Tue, 03 Apr 2018 17:03:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106817#106817</guid>
   <title>Potential R-Pod Owner with a Question : Thank you, Leo and Melissa.  How...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106816#106816</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8181" rel="nofollow">Mimo</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 5:00pm<br /><br />Thank you, Leo and Melissa.  How silly of me not to think of the search engine.  Will go have a look.  And thank you for your suggestion on the Rustoleum.<br />Mimo]]>
   <pubDate>Tue, 03 Apr 2018 17:00:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106816#106816</guid>
   <title>Potential R-Pod Owner with a Question : Welcome to the group! There have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106815#106815</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 4:57pm<br /><br /><div>Welcome to the group! There have been some mentions of soft spoke on the floors. There are various repair that members have done.</div><div>If you go to the search window, you can pull up some that might address your issue/model!</div><div>We have had some had some rust spots appear on the underneath area. I have sanded it down an used rustoleum on it.</div><div><br></div>]]>
   <pubDate>Tue, 03 Apr 2018 16:57:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106815#106815</guid>
   <title>Potential R-Pod Owner with a Question : Hello.I&amp;#039;ve been reading the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106814#106814</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8181" rel="nofollow">Mimo</a><br /><strong>Subject:</strong> 11350<br /><strong>Posted:</strong> 03 Apr 2018 at 4:51pm<br /><br />Hello.<div><br><div>I've been reading the forum for a couple of days because we are looking at buying a used <b>2011 R-Pod 172.</b></div><div><br></div><div>I live next to the Atlantic Ocean, and while the trailer has been well cared for, there is salt in our very air, so it is showing some rust and flaking paint on the steel support beams.&nbsp; That is to be expected here.&nbsp; The problem I'm seeing is that there is a <b>lot of give in the floor directly in front of the sink/stove</b> area, and when you look underneath, you can see that large panel bow as someone walks across.&nbsp; There is no support beam in this large area, directly in front of the wheels.&nbsp; There are some cables/pipes running across in the area.</div><div><br></div><div><b>My question is, has anyone else experienced a problem with this?&nbsp; If so what was the solution?&nbsp; And how involved was the fix?</b></div><div><br></div></div><div>Thank you for your help.&nbsp; We are reaching retirement age, and while we tested out our compatibility before we married by packing up the motorcycle and tenting for 2 weeks at a time, we are not willing to go back to sleeping on the ground.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /> But we travel well together and love to explore.&nbsp; I think the R-Pod would be a good solution.</div><div><br></div><div>Mimo</div>]]>
   <pubDate>Tue, 03 Apr 2018 16:51:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11350&amp;PID=106814#106814</guid>
