  <title>R-pod Owners Forum : tow vehicle</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : tow vehicle</description>
  <pubDate>Thu, 24 Sep 2026 11:24:29 +0000</pubDate>
  <lastBuildDate>Thu, 15 Mar 2018 21:06:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=11215</WebWizForums:feedURL>
   <title>tow vehicle : Hey Peas in a pod......... we...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105619#105619</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8076" rel="nofollow">Bully</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 15 Mar 2018 at 9:06pm<br /><br />Hey Peas in a pod......... we just bought a new 178 and are towing it with a 2014 Edge 3.5 with factory tow equipment. I pull in S and stay around 60-65.&nbsp; The last trip I got 12.8 mpg and have no problem pulling our trailer. We love our new pod.]]>
   <pubDate>Thu, 15 Mar 2018 21:06:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105619#105619</guid>
   <title>tow vehicle : The 2005 F150 has the harness...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105580#105580</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 14 Mar 2018 at 4:20pm<br /><br />The 2005 F150 has the harness built in for the brake controller, etrailer.com has a You Tube video on installation of a P3 brake controller and they have the harness required.  The connector is up under the dash and usually covered with a grey cover.  If you GOOGLE brake controller for a 2005 Ford F150 you will get all the pertinent info.  No relays are required.  Nothing is required but the brake controller, the harness and time.<br /><br />The FAQ section of etrailer.com is also a valuable resource.<br /><br />Here's a link to the video:<br />https://www.etrailer.com/tv-install-tekonsha-prodigy-p3-brake-controller-2005-ford-f150-90195.aspx<br /><br />I GOOGLED Brake Controller Install - 2005 F150.]]>
   <pubDate>Wed, 14 Mar 2018 16:20:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105580#105580</guid>
 </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105578#105578</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8100" rel="nofollow">peas in a pod</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 14 Mar 2018 at 4:13pm<br /><br />
   <pubDate>Wed, 14 Mar 2018 16:13:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105578#105578</guid>
   <title>tow vehicle : Most states require a TBC for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105577#105577</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 14 Mar 2018 at 3:22pm<br /><br />Most states require a TBC for trailers over 3,000 lbs. It differs by state about the exact requirement, but the gross weight of an RP-179 is close to 3,800 lbs, so you would expect to have to have the TBC with an RP-179.<br><br><a href="https://drivinglaws.aaa.com/tag/trailer-brakes/" target="_blank">Trailer Brakes by State</a><br>]]>
   <pubDate>Wed, 14 Mar 2018 15:22:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105577#105577</guid>
   <title>tow vehicle : I purchased a 2002 F150 5.4 Triton2...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105573#105573</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7950" rel="nofollow">disputin</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 14 Mar 2018 at 2:39pm<br /><br />I purchased a 2002 F150 5.4 Triton&nbsp;2 years ago.&nbsp; It doesn't have a tow package or tranny cooler installed.&nbsp; In January we drove it from Portland, OR to LA to pick up a 179, that came with a WBH.<div><br></div><div>We towed the 179 (empty) back to Portland, in a rush to get back to work, so our speed was 70 for most of the way back on US395.&nbsp; We went over Deadman summit at 8000+ feet.&nbsp; &nbsp;I watched and I never saw a temperature gauge move or change for the entire trip.&nbsp; The F150 was more than adequate to pull the 179.</div><div><br></div><div>You shouldn't have any problems.</div><div><br></div><div>Sean &amp; Christine Whitney</div><div>2002 F150</div><div>2016 179</div>]]>
   <pubDate>Wed, 14 Mar 2018 14:39:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105573#105573</guid>
   <title>tow vehicle :      Originally posted by...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105571#105571</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 14 Mar 2018 at 1:20pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by peas in a pod</strong></em><br /><br />mr and mrs pea have become owners of a 2005 F-150 5.4L triton pu.&nbsp; was a wondering if we will have to install a trany cooler.&nbsp; we have the bumper hook up 7 way plug and a 4 way plug but no module under the dash. I am assuming that the plug receptacle under the dash is a diagnostic port?&nbsp; we still haven't found our Rpod&nbsp; but maybe somebody out there would provide us with one.any concerns about the f150?<div>mr pea</td></tr></table>The plug you're seeing is most probably the OBD (On Board Diagnostics) port. It for checking various system conditions on the engine and other monitored systems.<br><br>The OBD port looks like this:<br>&nbsp;<br><img src="http://www.electroboost63.fr/wp-c&#111;ntent/uploads/2016/03/obd-450x338.jpg" height="338" width="450" border="0" /><br><br>You "probably" have a TBC (Trailer Brake Controller) connector buried somewhere under the dash as well. I think on that vintage of F-150, there might be a cutout somewhere above the driver's right knee for the TBC, and the connector plug would be right behind that. If you install the TBC (and I recommend that you do), then you will probably also need to install a small relay to provide power to the TBC and trailer brakes.<br></div>]]>
   <pubDate>Wed, 14 Mar 2018 13:20:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105571#105571</guid>
   <title>tow vehicle : mr and mrs pea have become owners...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105568#105568</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8100" rel="nofollow">peas in a pod</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 14 Mar 2018 at 12:40pm<br /><br /><div>mr and mrs pea have become owners of a 2005 F-150 5.4L triton pu.&nbsp; was a wondering if we will have to install a trany cooler.&nbsp; we have the bumper hook up 7 way plug and a 4 way plug but no module under the dash. I am assuming that the plug receptacle under the dash is a diagnostic port?&nbsp; we still haven't found our Rpod&nbsp; but maybe somebody out there would provide us with one.</div><div>any concerns about the f150?</div><div>mr pea</div>]]>
   <pubDate>Wed, 14 Mar 2018 12:40:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105568#105568</guid>
   <title>tow vehicle : If I could afford to buy a new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105501#105501</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 13 Mar 2018 at 8:32am<br /><br />If I could afford to buy a new Ford 150, I'd do it. &nbsp;But in the meantime, I'll manage with our Dakota.]]>
   <pubDate>Tue, 13 Mar 2018 08:32:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105501#105501</guid>
   <title>tow vehicle : We have a 2011 f150 with the eco...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105494#105494</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1895" rel="nofollow">Craneman</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 12 Mar 2018 at 10:11pm<br /><br />We have a 2011 f150 with the eco boost and love it<div>&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Moe</div>]]>
   <pubDate>Mon, 12 Mar 2018 22:11:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105494#105494</guid>
   <title>tow vehicle : Thanks coyote, that is good info...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105491#105491</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 12 Mar 2018 at 9:16pm<br /><br />Thanks coyote, that is good info to know.&nbsp; Think I will start casually looking at used Fords with ecoboost, was 2013 one of the first years they installed them in the F-150?]]>
   <pubDate>Mon, 12 Mar 2018 21:16:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105491#105491</guid>
   <title>tow vehicle : I have a 2013 F-150 Ecoboost Ford...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105391#105391</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6458" rel="nofollow">crazycoyote</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 11 Mar 2018 at 7:25pm<br /><br />I have a 2013 F-150 Ecoboost Ford 4 door truck, bought it new in 2013 and so far have 1004 thousand miles on it, still like new, changed out the front rotors when I bought it, due to a Ford front end shake, cheep stock Rotors, other than that, runs like new. I'll keep until it dies. &nbsp;]]>
   <pubDate>Sun, 11 Mar 2018 19:25:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105391#105391</guid>
   <title>tow vehicle : Leo, the engine is still very...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105386#105386</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 11 Mar 2018 at 6:48pm<br /><br />Leo, the engine is still very strong as well as the clutch and throw out bearing.&nbsp; Main issue is with the deteriorating body, getting a fair amount of rust, especially in those areas where deer have met their doom.]]>
   <pubDate>Sun, 11 Mar 2018 18:48:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105386#105386</guid>
   <title>tow vehicle : Boy I would love to get 315,000...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105350#105350</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 11 Mar 2018 at 8:39am<br /><br />Boy I would love to get 315,000 out of our F-150!! &nbsp;]]>
   <pubDate>Sun, 11 Mar 2018 08:39:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105350#105350</guid>
   <title>tow vehicle :   Originally posted by jatoThanks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105348#105348</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 11 Mar 2018 at 12:45am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by jato</strong></em><br /><br />Thanks GlueGuy !&nbsp; Next question is how long can one expect an ecoboost engine to last in miles, such as the 3.5L?&nbsp; Curious as my 94 F-150 with a 5.0L V8 is beginning to get a bit tired and rusty with 315,000 Michigan salt miles on it.&nbsp; Also the 31 deer kills have not helped either, nor all the other "hits" (I haven't kept track of those) where they only got maimed and limped off the road.</td></tr></table>The bottom end (crank, journals, and piston rods) on EcoBoost engines are built like diesel engines. Both the 2.7L EcoBoost and the 3.5L EcoBoost are built with 6-bolt main bearings (that is not a misprint). In the "old days" one sign of a so-called bullet-proof engine was the use of 4-bolt mains. Well, these engines are built very seriously. The original EcoBoost engines have been around almost 10 years now (first production in 2009 for the 2010 model year), and it looks like Ford is going all in. Their track record is very good by all accounts.<br>]]>
   <pubDate>Sun, 11 Mar 2018 00:45:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105348#105348</guid>
   <title>tow vehicle : Thanks GlueGuy ! Next question...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105345#105345</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 9:37pm<br /><br />Thanks GlueGuy !&nbsp; Next question is how long can one expect an ecoboost engine to last in miles, such as the 3.5L?&nbsp; Curious as my 94 F-150 with a 5.0L V8 is beginning to get a bit tired and rusty with 315,000 Michigan salt miles on it.&nbsp; Also the 31 deer kills have not helped either, nor all the other "hits" (I haven't kept track of those) where they only got maimed and limped off the road. &nbsp;]]>
   <pubDate>Sat, 10 Mar 2018 21:37:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105345#105345</guid>
   <title>tow vehicle : Based on the EcoBoost engines...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105344#105344</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 9:08pm<br /><br />Based on the EcoBoost engines I have seen, you can almost double the effective "displacement" of an EcoBoost engine. IOW, the 2.7L EcoBoost performs like a 5.4L engine, and the 3.5L EcoBoost performs like a 7L engine. The second generation of the 3.5L EcoBoost is now producing ~~ 470 ft-lbs of torque, and it's still a flat curve.]]>
   <pubDate>Sat, 10 Mar 2018 21:08:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105344#105344</guid>
   <title>tow vehicle : Interesting. That illustrates...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105341#105341</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 8:32pm<br /><br />Interesting. That illustrates why the 2L Ecoboost engine in our former Escape outperformed the 4L NA engine in our current Frontier, even with 2 less cylinders.<br><br>]]>
   <pubDate>Sat, 10 Mar 2018 20:32:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105341#105341</guid>
   <title>tow vehicle :    Originally posted by lostagainAnd...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105325#105325</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 11:02am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by lostagain</strong></em><br /><br />And keep in mind that with torque, it increases up to a point with increased engine rpm, but then starts a rapid decline despite the fact that the engine is going faster and faster. &nbsp;Once you hit your maximum torque, there is little point in trying to go faster or make the engine turn faster because you'll only lose relative motive force. &nbsp;When you hit your maximum torque, stick with that speed if you can. &nbsp;If you can't sustain your speed, it's time to downshift.</td></tr></table>Generally true, but there are exceptions to the rule. The "peaking" of the torque curve is a classic characteristic of a normally aspirated (NA) engines. Boosted engines behave quite differently. <br><br>The graph below shows the torque curves for 4 engines, a 6.2L V8, a 5.0L V8, and an early version of the 3.5L EcoBoost, and the 3.7L (NA) V6. On the face of it, you might think that the 6.2L V8 is the stronger engine with 438 ft-lbs, but that torque happens at ~~ 4800 RPM.<br><br>By contrast, the 3.5L EcoBoost "only" produces 420 ft-lbs of torque, but that torque happens at ~~ 2400 RPM, and it stays there all the way up to ~~ 4500 RPM. This is what is called a "flat torque curve", and it is a feature of many/most diesel engines. It is very desirable for vehicles that have to tow.<br><br>For example, if the speed you're going requires the engine to run at 2000 RPM, the 6.2L V8 is producing a little under 300 ft-lbs, the 5.0L V8 is producing slightly over 200 ft-lbs, but the 3.5L is already producing just a shade over 400 ft-lbs. If you were cruising along and came upon a big uphill grade, which engine would be able to maintain 2000 RPM? <br><br>We've been driving our EcoBoost F-150 now for almost 3 years, and it is really a stump puller. That flat torque curve is amazing when it's at work.<br><br><br><img src="https://www.ford-trucks.com/forums/members/austincobra-albums-ecoboost-picture60378-torquecurves.jpg" height="333" width="600" border="0" /><br>]]>
   <pubDate>Sat, 10 Mar 2018 11:02:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105325#105325</guid>
   <title>tow vehicle : And keep in mind that with torque,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105322#105322</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 9:37am<br /><br />And keep in mind that with torque, it increases up to a point with increased engine rpm, but then starts a rapid decline despite the fact that the engine is going faster and faster. &nbsp;Once you hit your maximum torque, there is little point in trying to go faster or make the engine turn faster because you'll only lose relative motive force. &nbsp;When you hit your maximum torque, stick with that speed if you can. &nbsp;If you can't sustain your speed, it's time to downshift.]]>
   <pubDate>Sat, 10 Mar 2018 09:37:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105322#105322</guid>
   <title>tow vehicle : Torque matters even more than...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105318#105318</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 8:07am<br /><br />Torque matters even more than horsepower when towing. You can have a lot of horsepower, but unless you can get that power to the wheels (torque) and get that torque to the ground (traction), you won't have much success in towing. Think a sports car (lots of horsepower but not as much torque) vs. a tractor (lots of torque but not much horsepower).&nbsp; 2011 Edge 3.5L had 285 hp at 6500 rpm and 253 lb-ft at 4,000 rpm when it was new. At 6+ years old, performance may not be as good due to wear. The 2L Ecoboost engine in the Escape had 240 hp at 5500 rpm and 270 lb-ft at 3000 rpm. A Ford F-150 with the 3.5L Ecoboost engine develops 375 hp and 470 lb-ft torque and the Raptor High Output 3.5L engine develops 450 hp and 510 lb-ft torque. The higher torque number with more than adequate horsepower means a better towing experience.<br><br>As for purchasing an R-Pod, not all dealers try to jack up the prices. Are you considering new or used? <br>Check <a href="http://www.rvtrader.com" target="_blank">RV Trader</a> to see what kind of deal you can find.<br>]]>
   <pubDate>Sat, 10 Mar 2018 08:07:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105318#105318</guid>
   <title>tow vehicle : jato and Stephen H, Thanks for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105316#105316</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8100" rel="nofollow">peas in a pod</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 7:00am<br /><br /><div>jato and Stephen H,&nbsp; Thanks for your input, we see the logic in having an HP edge to make your travels safer, which is the prime directive in hauling a camper.&nbsp; we are pod-less now and have been enamored with them.&nbsp; however, I've been seeing the reports as to the inflation of prices on behalf of profit seekers and retailers.&nbsp; that brings some other camper models into consideration.&nbsp; We are seriously working toward your suggestions.&nbsp; A Ford 150 pu may be in our future.</div><div><br></div><div>thanks a bunch</div><div>Mr. &amp; Mrs Pea</div>]]>
   <pubDate>Sat, 10 Mar 2018 07:00:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105316#105316</guid>
 </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105315#105315</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8100" rel="nofollow">peas in a pod</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 10 Mar 2018 at 6:52am<br /><br />
   <pubDate>Sat, 10 Mar 2018 06:52:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105315#105315</guid>
   <title>tow vehicle : Hello and welcome! If you decide...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105302#105302</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 09 Mar 2018 at 6:32pm<br /><br />Hello and welcome! If you decide to get the 'Pod, I hope you have many fine adventures and make many great memories doing so.<br><br>Now, I am going to take a contrary position. We towed about 10,000 miles with your 2016 Ford Escape SE which also had a 3500 lb tow rating. Due to an accident, we had to change and now tow with a 2010 Nissan Frontier LE Crew Cab. My observations may help.<br><br>1st. A longer tow vehicle does not necessarily guarantee a better towing experience. The distance between the center of the rear axle and the hitch ball affect the towing experience more than vehicle length alone.&nbsp; With the Escape, the distance was about 3-1/2 feet. With the Frontier, it is more like 5-1/2 feet. That extra 2 feet means the R-Pod can exert more force on the tow vehicle. We certainly notice it more with the Frontier than we did with the Escape when a tractor-trailer passes, even though the Frontier has a 6100 lb tow rating.<br><br>2nd, what counts more is whether your Edge is FWD or AWD/4WD. If it is FWD, then you will absolutely need a well-adjusted Weight Distribution Hitch with sway control provided by the hitch (Equal-i-zer, Fastway E2, or Andersen No-Sway or equivalent). or a separate sway bar. The issue is the traction you need. Without a WDH, too much weight will be taken off the front end which affects both your traction and steering. Even with AWD/4WD, steering would be affected, even if the rear wheels are providing traction. The Edge would require a WDH in any case. Check Ford's Towing Guide for the Edge for just what is needed. A longer, heavier vehicle with a higher tow rating is desirable, but if it is not a current option, you could use your Edge. The lightest R-Pod that will meet your needs would be a better choice than the heavier ones that are close to the capacity of your Edge.<br><br>Last is engine size. My Frontier has a 4L naturally aspirated engine. I believe the 3.5L in your Edge is also naturally aspirated (not turbocharged, or Ecoboost as Ford calls it). That means for every 1000 feet you increase in elevation, you should expect to lose 4% in power. As long as you stay at lower elevations, you will be okay. Don't count on a trip to the Rockies with it. The Appalachians will be more than enough of a challenge to that engine. Mountains are a challenge for the Frontier as well. Turbocharged engines do much better as they don't lose power at higher elevations. They do require premium fuel though.<br><br>Bottom line is that while you may be able to use the Edge, you would want to change out for a vehicle with a higher tow rating when you are able.<br>]]>
   <pubDate>Fri, 09 Mar 2018 18:32:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105302#105302</guid>
   <title>tow vehicle : Have to agree with lostagain....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105287#105287</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 09 Mar 2018 at 4:18pm<br /><br />Have to agree with lostagain.&nbsp; It is no fun being on the precipice of towing capacity and also the fact that the Edge has a relatively short wheel base.&nbsp; As Fred noted above, mountainous and/or steep climbs and descents will take its toll on you as well as your Edge.&nbsp; We have towed our 177 (empty weight 2450 lbs.) with two different Explorers and have had relatively good experiences with both.<br><br>IF you only plan on traveling where it is relatively flat or close to home down yonder in Georgia, you should be ok.<br>]]>
   <pubDate>Fri, 09 Mar 2018 16:18:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105287#105287</guid>
   <title>tow vehicle : Welcome to the group. Hope you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105254#105254</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 09 Mar 2018 at 8:36am<br /><br />Welcome to the group. &nbsp;Hope you enjoy your new Pod. &nbsp;<div><br></div><div>As for tow vehicles, towing on the edge of the capacity of your Edge will work for a bit, but eventually you will be frustrated, and the wear and tear on your car will become more and more noticeable. &nbsp;If you are going to use your Pod a lot and travel in any areas with steep climbs and descents, you would probably be much more satisfied with a tow vehicle that has a capacity greater than the loaded weight of your Pod and all the stuff &nbsp;you will be carrying in your car. &nbsp;</div><div><br></div><div>The gas mileage savings will be cost effective only if you drive &nbsp;your tow vehicle with the trailer attached a lot more than you use it just as regular transportation. &nbsp;But, that being said, when you are on a long upgrade and the tractor trailer are passing you and your engine heat is rising, you may wish for a little more towing capacity.</div>]]>
   <pubDate>Fri, 09 Mar 2018 08:36:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105254#105254</guid>
   <title>tow vehicle : Welcome to the Group!! We have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105252#105252</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 09 Mar 2018 at 8:23am<br /><br /><div>Welcome to the Group!! We have a 179 that we used to tow with our Dodge Grand Caravan with the 6 cyl penstar engine 283 horse power. We towed up and down the east coast, always felt safe but were always on the edge of the limits. We also previously had a 171 and loved it, but like the extra room/slide out of the large pods. That towed a bit easier.</div><div>We then upgraded our tow vehicle to a F-150 with the 5.0 v-8 and really love it. The mpg is&nbsp; 1-2 mpg lower but the power and ease of towing&nbsp; makes it well worth while.&nbsp;</div>]]>
   <pubDate>Fri, 09 Mar 2018 08:23:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105252#105252</guid>
   <title>tow vehicle : hello, I am bob and wife is sherri....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105251#105251</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8100" rel="nofollow">peas in a pod</a><br /><strong>Subject:</strong> 11215<br /><strong>Posted:</strong> 09 Mar 2018 at 7:40am<br /><br /><div><img src="https://www.rpod-owners.com/smileys/smiley38.gif" border="0" alt="Lamp" title="Lamp" /> hello, I am bob and wife is sherri.&nbsp; we are looking for an R-Pod 180 and have purchased the towing equipment (tow bar, sway bar, brake package, and tranny cooler), for our 2011 3.5L ford edge.&nbsp; it seems that we are on the edge of gvwt limits and we were wondering if the hook up stuff I have will keep us safe?&nbsp; should we move to perhaps a R-pod 171?&nbsp; What say ya'll?</div><div>peas in a pod.</div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div>9&nbsp;</div>]]>
   <pubDate>Fri, 09 Mar 2018 07:40:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=11215&amp;PID=105251#105251</guid>
