  <title>R-pod Owners Forum : Pet Peeve - pun intended</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Camping with pets : Pet Peeve - pun intended</description>
  <pubDate>Sat, 07 Nov 2026 05:07:04 +0000</pubDate>
  <lastBuildDate>Fri, 06 Jun 2014 13:22:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=1121</WebWizForums:feedURL>
   <title>Pet Peeve - pun intended : Definitely the easier solution,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46840#46840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 06 Jun 2014 at 1:22pm<br /><br />Definitely the easier solution, MM. &nbsp;<img src="https://www.rpod-owners.com/smileys/smiley16.gif" border="0" alt="Cool" title="Cool" />]]>
   <pubDate>Fri, 06 Jun 2014 13:22:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46840#46840</guid>
   <title>Pet Peeve - pun intended : OK... reading all this tells me...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46838#46838</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 06 Jun 2014 at 10:00am<br /><br />OK... reading all this tells me to go back to square one. Don't leave any critter in car ( our Winters don't get  cold enough that several blankets to snuggle in won't do) in heat. Looks to me back to fast food if on road with animals, besides they always want a bite if they are hanging out over your head while you eat.]]>
   <pubDate>Fri, 06 Jun 2014 10:00:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46838#46838</guid>
   <title>Pet Peeve - pun intended :  Does a running parked vehicle...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46815#46815</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2707" rel="nofollow">Budward</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 05 Jun 2014 at 4:46pm<br /><br />Does a running parked vehicle have to attended by humans?<img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" /><br><br>The Toyota was much easier to rig up than the diesel pickup*, only needed one relay to bridge the run power into and out of the ignition switch.&nbsp; There is also a switch that picks up the brake pedal being pushed, which would be necessary to attempt to get the transmission out of park,&nbsp; and shuts&nbsp; the vehicle down.&nbsp; You can't re-engage it without the key.<br>Speaking of over temp-&nbsp; I forgot I also found a talking thermometer with a temperature alarm setpoint-&nbsp; it is placed to activate the VOX on the 2 ways and lets us know if the cooling failed or was inadequate.&nbsp;&nbsp; I found it at Radio Shack several years ago, just checked, they no longer sell it.<br><br>*The diesel pickup system started as a turbo cool down timer-&nbsp; IOW when exhaust gas temp is high but I want shut off and leave the vehicle- I activate the timer, it runs the engine for a few minutes then shuts down- again the vehicle can't driven in this mode.&nbsp; Transmission locked in park, steering wheel locked etc..&nbsp; After making all that work it occured to me it could be used as a dog cooler too!<br><br>Man- the stuff we go through for our beloved pets<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" /><br>]]>
   <pubDate>Thu, 05 Jun 2014 16:46:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46815#46815</guid>
   <title>Pet Peeve - pun intended : It just occured to me that you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46807#46807</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 05 Jun 2014 at 2:04pm<br /><br />It just occured to me that you could go a different route, which would work with any car/truck, and would be even easier to figure out.&nbsp; Start the vehicle with the key, leaving it in the ignition (or for newer cars with keyless ignitions, take it with you).&nbsp; Additional circuitry needed would only need to tap the overhead light circuit, brake light circuit, maybe even add a wire you could tightly weave through the steering wheel so if it is turned it would unplug.&nbsp; Any of these things are triggered, kill the ignition system and sound the horn.&nbsp; Add to the big sign on the driver's window "vehicle will shut off if entered", and add a steering wheel lock (I know they can be easily defeated, just have it for visual impact).&nbsp; That design would be very simple, and again most of it would be universal for any vehicle.<DIV>&nbsp;</DIV><DIV>The big caveat to any of these designs, including Budward's, is many jurisdictions have fines for leaving a vehicle on but unattended.</DIV>]]>
   <pubDate>Thu, 05 Jun 2014 14:04:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46807#46807</guid>
   <title>Pet Peeve - pun intended : If a vehicle already has remote...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46806#46806</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 05 Jun 2014 at 1:46pm<br /><br />If a vehicle already has remote start capability it would be fairly easy to hack a remote with some additional electronics, to "push" the start button after it senses the vehicle has shut down (since most remote start systems will only stay on for 10-15 minutes).&nbsp; <DIV>&nbsp;</DIV><DIV>Downsides are the need for a dedicated remote, and it would add some additional start cycles to the starter and engine.&nbsp; Not something you would want to use for hours at a time UNLESS the vehicle was a hybrid OR one of the newer non-hybrid models which shuts off at traffic lights.&nbsp; Both types are designed for tens of thousands of extra starting cycles.&nbsp; I could keep the A/C running for days on one tank of gas in my Prius.</DIV><DIV>&nbsp;</DIV><DIV>The advantage would be very little additional circuitry needed and almost no change to the vehicle other than tapping +12, ground, and an accessory wire that you've tested goes low when the engine shuts off.&nbsp; Probably just a standard accessory tap would work but you may have to go as far as tapping the power to the ignition system to be sure.&nbsp; The core design would be the same for any vehicle.</DIV><DIV>&nbsp;</DIV><DIV>You could take it a step further for safety and add a temperature probe and some additional circuitry that will sound the car horn if it gets too hot in the car.&nbsp; That would add one more tap for the car horn. </DIV>]]>
   <pubDate>Thu, 05 Jun 2014 13:46:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46806#46806</guid>
   <title>Pet Peeve - pun intended : mentioned this to my roofer yesterday....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46804#46804</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 05 Jun 2014 at 9:36am<br /><br />mentioned this to my roofer yesterday. he has a Yorkie who is Boss. goes everyplace with him. <br />the cars with punched in code is how he does it. leaves it running, locks up with ac on for little one. never to far from it, since he is boss man , doing none of the actual work on roofs now.<br />I still get to wondering if someone could make off with the car in some way. Darn hackers are into everything<br />if lady was new to US she just did not think. They may eat their dogs. I KNOW that may not nice thing to say, but we live and think differently here. I may get a load down on my head for having said this., but different countries have different outlook. After all we eat cows... India, maybe not.<br />But my blonde, chocolate brown huge eyed Labradoodle grand daughter dog is sooo funny and that tail is a table cleaner. ]]>
   <pubDate>Thu, 05 Jun 2014 09:36:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46804#46804</guid>
   <title>Pet Peeve - pun intended : Seems to me the dogs weren&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46799#46799</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 05 Jun 2014 at 6:36am<br /><br />Seems to me the dogs weren't bothering anyone and were just vegging. She needed to understand her behavior was unacceptable<img src="https://www.rpod-owners.com/smileys/smiley4.gif" border="0" alt="Big smile" title="Big smile" />]]>
   <pubDate>Thu, 05 Jun 2014 06:36:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46799#46799</guid>
   <title>Pet Peeve - pun intended : For her or the dogs?   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46792#46792</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2707" rel="nofollow">Budward</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 9:21pm<br /><br />For her or the dogs?]]>
   <pubDate>Wed, 04 Jun 2014 21:21:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46792#46792</guid>
   <title>Pet Peeve - pun intended : Another case for pepper spray?...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46789#46789</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 8:35pm<br /><br />Another case for pepper spray?]]>
   <pubDate>Wed, 04 Jun 2014 20:35:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46789#46789</guid>
   <title>Pet Peeve - pun intended :    Originally posted by mountain...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46784#46784</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2707" rel="nofollow">Budward</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 8:06pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by mountain mist</strong></em><br /><br />Good for you to have found a way for your dogs to go but be left in car. we always had dogs in the motorcoaches, anytime stopped(as to eat out on the road) we left the ac on for them.  Would be interested (as a non-mechanical person) how you did the set up if I should find myself needing to use it.</td></tr></table><br><br>The system I devised is rather complicated and depends on the vehicle.&nbsp;&nbsp; On my 96 diesel it required quite a bank of relays.&nbsp; On my 11 Toyota it was simpler, but one has to be <i>very</i> cautious tapping into wiring on late model vehicles, it would easy to blow a $1000+ computer.<br><br><br><br><br>&nbsp;<table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by mountain mist</strong></em><br /><br />Note one of your dogs is a Labradoddle, son has one, just eat you up with kisses!</td></tr></table><br>That sure is true! Ours is a hoot...he loves to watch me working on things, its like he is thinking- hey I could do that if I had thumbs!&nbsp;&nbsp; He also loves to catch me with both hands occupied, laying on the ground under some trailer and give me a good ear licking<img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" /><br><br><br><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by mountain mist</strong></em><br /><br />But the woman, tapping on the window to see AMERICAN dogs, LOL , how different are Asian dogs?</td></tr></table><br><br>We were very puzzled by this woman's strange behavior, her and her husband had apparently just arrived in the US, no idea where from but dogs must have been a rarity.&nbsp; She spoke very little English and seemed unconcerned we were so upset at her.&nbsp; The dogs scratched the heck out of the plastic interior door trim trying to get at her as she antagonized them<img src="https://www.rpod-owners.com/smileys/smiley7.gif" border="0" alt="Angry" title="Angry" /><br>I am horrified to think what might have happened if the window had broken!<br><br><br><br><br><br><br>]]>
   <pubDate>Wed, 04 Jun 2014 20:06:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46784#46784</guid>
   <title>Pet Peeve - pun intended : I plan to go over to Four Paws...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46768#46768</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 9:51am<br /><br />I plan to go over to Four Paws Kingdom and rent a camper with the dog. Soon as I get the house back in order]]>
   <pubDate>Wed, 04 Jun 2014 09:51:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46768#46768</guid>
   <title>Pet Peeve - pun intended : Congrats on finding a good buyer,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46767#46767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 9:44am<br /><br />Congrats on finding a good buyer, MM.&nbsp; Maybe you can still get some camping in by renting a campground cabin?]]>
   <pubDate>Wed, 04 Jun 2014 09:44:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46767#46767</guid>
   <title>Pet Peeve - pun intended : PS My little schnauzer, Trudi,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46761#46761</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 7:58am<br /><br />PS<br />My little schnauzer, Trudi, lived for 14 good years. She left us in February, waiting for me at Rainbow Bridge.]]>
   <pubDate>Wed, 04 Jun 2014 07:58:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46761#46761</guid>
   <title>Pet Peeve - pun intended : My Pod is sold, last month, alas....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46760#46760</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 7:56am<br /><br />My Pod is sold, last month, alas. Alas for me, I am going to MISS camping, but good to have sold and to someone who REALLY wanted it, was pleased with the condition it was in, Happy Camping to them. suggested this site to them. One big family.<br />BUT , remarking on this about dogs. Good for you to have found a way for your dogs to go but be left in car. we always had dogs in the motorcoaches, anytime stopped(as to eat out on the road) we left the ac on for them.  Would be interested (as a non-mechanical person) how you did the set up if I should find myself needing to use it. Note one of your dogs is a Labradoddle, son has one, just eat you up with kisses!<br />But the woman, tapping on the window to see AMERICAN dogs, LOL , how different are Asian dogs?<br />If we have our dog/dogs with us on a road trip, we have the worse diet of drive in food so as NOT, EVER, leave in car. Only in cold weather do we leave and then they have piles of blankets to cuddle in.<br />On my Facebook there is picture of smashed car window with the caption" this is what you will see if you have left an animal in the car on a hot day". In truth, call the police, stay with the car and file a complaint on the person with the car. of course, same goes for some nut head who has left a child in the car.]]>
   <pubDate>Wed, 04 Jun 2014 07:56:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46760#46760</guid>
   <title>Pet Peeve - pun intended :    Originally posted by Brin...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46756#46756</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2707" rel="nofollow">Budward</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 04 Jun 2014 at 5:48am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Brin</strong></em><br /><br />&nbsp; I still find that I like my dog better than most people that I have met.&nbsp;</td></tr></table><br><br>I have a saying-&nbsp; Dogs are the best people ever!<br><br>It is a pain traveling with dogs, especially in hot weather and the need to leave them in the car.<br>I designed and installed a system in both my tow vehicles where I can leave the vehicle running with the AC on, yet the key is not in it and it can't be driven if someone was bold/stupid enough to break in and try with with 2 50lb+ dogs in it.&nbsp; I even have a sign I place on the dash with my cell number if there are any concerns about the dogs in the running truck.&nbsp;&nbsp;&nbsp; Even so we never do this even for as much as one hour, usually to grab a lunch or something.<br>We also leave a handheld 2 way radio inside with the VOX on so if the dogs bark it keys the radio and we hear it.&nbsp; Had some funny looks when dog barking suddenly started coming from the radio on my hip<img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" /><br><br>My wife was once livid when she came out of a Walmart to find an asian lady tapping on our truck window while our dogs were going berserk at her.&nbsp; She wanted her child, who she was holding up to the truck window,&nbsp; to see American dogs that were in our truck.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><br><br>]]>
   <pubDate>Wed, 04 Jun 2014 05:48:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=46756#46756</guid>
   <title>Pet Peeve - pun intended : I don&amp;#039;t much care whether...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=43068#43068</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 02 Mar 2014 at 12:20am<br /><br />I don't much care whether people follow the letter of the law (rules) regarding pets, but I want them to follow their spirit. If the rules say dogs need to be on a leash no longer than 6 feet, if you can keep your dog out of everyone's way in your campground with a 20 lead, I don't care. &nbsp;If you don't pick up after your dog in the woods totally off the path, I don't care.&nbsp; If you dog poops anywhere near my camping spot and I see you, we're likely to have a little conversation.<br><br>I've always had dogs, usually more than one at a time.&nbsp; While we had two we opted to board them when we camped.&nbsp; We were also camping in a tent at the time and really didn't have room for dogs in the car or tent.&nbsp; We're down to one little dog now, a Jack Russell, and have the pod.&nbsp; She's a great traveling companion and after a few trips with her I can't imagine not taking her now wherever we go.<br><br>I pick up after her, and she goes with us when we leave the campground. <br><br>I'm kind of stickler for campground rules.&nbsp; We purposely camp at off-times, like going to the Smokies in January.&nbsp; Even when we are the only ones in the campground we pretty much follow the rules.&nbsp; (I've been known to run the generator all night when a tree wouldn't even make a sound when it fell though, but I figure the rules are mostly about respecting each others' peace and quiet anyway.)&nbsp; It bothers me that many National Parks don't seem to have the budget for rangers or campground hosts who, if they exist at all, do anything about even flagrant rules violations, about pets, kids, or anything else.&nbsp; I swear, you could get away with murder as long as you don't leave the body where someone will have to step over it, and sometimes even then.<br><br>Most campers are good people who do respect each others' peace and quiet, but there are some who are out for their own good time regardless of those around them, and there are some newbies who obviously don't know what's expected.&nbsp; Pets are one of the easiest ways to annoy other people, but certainly not the only way!<br><br>We've been to Big Bend a couple of times and the same campground host was there both times at Chisos Basin.&nbsp; He was exceptional.&nbsp; He'd walk slowly through the campground at least twice a day, help people get set up, talk to those who wanted to talk or ask questions, and he talked to the people who needed talking to.&nbsp; Everyone who didn't already know or care about the rules got polite little lessons.&nbsp; It made the whole experience better for everyone I think.<br><br>TT<br>]]>
   <pubDate>Sun, 02 Mar 2014 00:20:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=43068#43068</guid>
   <title>Pet Peeve - pun intended : Enjoying the discussion.  We have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=43066#43066</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2556" rel="nofollow">GlobeTrotter</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 01 Mar 2014 at 10:02pm<br /><br />Enjoying the discussion. &nbsp; We have two Goldens who love to travel. &nbsp;We have always had them on a leash or short cable when they are outside. &nbsp;AND we do not leave them outside alone even if restrained. &nbsp;However, we have had great success with an invisible electric fence at our home and purchased a "rock" invisible fence for camping. &nbsp; A wire is connected to the energized rock and you string it out in the area you want to restrain your dog. &nbsp;We have not used it yet. &nbsp;Has anyone used such a device and if so, how effective is it? &nbsp;]]>
   <pubDate>Sat, 01 Mar 2014 22:02:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=43066#43066</guid>
   <title>Pet Peeve - pun intended : Hope not to see you sell, but...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30161#30161</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 10 Jan 2013 at 12:32pm<br /><br />Hope not to see you sell, but if you do you are still welcome to hang out here.&nbsp; ]]>
   <pubDate>Thu, 10 Jan 2013 12:32:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30161#30161</guid>
   <title>Pet Peeve - pun intended :   thank you P&amp;amp;M </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30151#30151</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 09 Jan 2013 at 6:36pm<br /><br />thank you P&amp;M]]>
   <pubDate>Wed, 09 Jan 2013 18:36:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30151#30151</guid>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30145#30145</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1442" rel="nofollow">P&M</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 09 Jan 2013 at 9:30am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by mountain mist</strong></em><br /><br />have not checked in for some time. was good to hear from people with Pods. still same rules for me when it comes to my dogs. I have the same (13 yr.oldnow ) and a new one , 9 months. Young one has been on one camping trip, still not sure if he likes it since it rained much of the time and was in November( not too sure I liked it either!). only 2 camping trips out last year due to other things taking away the time. hope to do better this year or I will be selling my Pod. Husband did ask if we can advertised on this site to sell. I am not sure just where to put it, since I am not greatly in the mood to do so, wanting to give it another try. But if I can be directed to the proper place to put a "for sale" then I will know when the time comes.</td></tr></table><div>&nbsp;</div><div>Mountain Mist, there is a "Campers Fleamarket" section that is right underneath the "Camping with Pets" section in the directory here ... that is where everyone has been posting their Pods for sale at.</div>]]>
   <pubDate>Wed, 09 Jan 2013 09:30:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30145#30145</guid>
   <title>Pet Peeve - pun intended :   have not checked in for some...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30144#30144</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 09 Jan 2013 at 8:43am<br /><br />have not checked in for some time. was good to hear from people with Pods. still same rules for me when it comes to my dogs. I have the same (13 yr.oldnow ) and a new one , 9 months. Young one has been on one camping trip, still not sure if he likes it since it rained much of the time and was in November( not too sure I liked it either!). only 2 camping trips out last year due to other things taking away the time. hope to do better this year or I will be selling my Pod. Husband did ask if we can advertised on this site to sell. I am not sure just where to put it, since I am not greatly in the mood to do so, wanting to give it another try. But if I can be directed to the proper place to put a "for sale" then I will know when the time comes.]]>
   <pubDate>Wed, 09 Jan 2013 08:43:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30144#30144</guid>
   <title>Pet Peeve - pun intended : One of the things that drew us...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30136#30136</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1464" rel="nofollow">coopercdrkey</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 08 Jan 2013 at 5:53pm<br /><br />One of the things that drew us to RV-ing was the opportunity to take the Campin' Cocker Spaniels with<div>us. &nbsp;They are never left alone. &nbsp;They bark if someone enters our site, until we assess the situation, then</div><div>they are hushed if there is no problem. &nbsp;They are walked numerous times per day, and always picked up</div><div>after. &nbsp;(There's a sentence ending in <i style="font-weight: bold; ">two</i>&nbsp;prepositions!)</div><div><br></div><div>Once, while walking them <i>on a leash</i>, we passed a site that had two Lhasa Apsos running free. &nbsp;They</div><div>basically assaulted Jennifer and Baxter, and the only reason they weren't eaten is that the spaniels were</div><div>caught entirely by surprise. &nbsp;(I call them <i>"Laughing A$$holes"</i>, and they looked like a pair of angry bedroom</div><div>slippers....)</div><div><br></div><div>I'll be very happy to control my pack. &nbsp;You have to control yours!</div>]]>
   <pubDate>Tue, 08 Jan 2013 17:53:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30136#30136</guid>
   <title>Pet Peeve - pun intended : We always take our Lab ,all 86...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30133#30133</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1368" rel="nofollow">bc matell</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 08 Jan 2013 at 5:04pm<br /><br />We always take our Lab ,all 86 pounds with us if we leave the campsite. When we are in camp she is on a 20 foot lead. She does bark at people walking by but only a few warning barks. We DO pick up after her. Nothing makes me madder than dog people who don't!]]>
   <pubDate>Tue, 08 Jan 2013 17:04:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=30133#30133</guid>
   <title>Pet Peeve - pun intended : I got a good chuckle out of that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=10775#10775</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 23 Jun 2010 at 4:28pm<br /><br />I got a good chuckle out of that mental image - the dog with front paws on the horn, barking and blowing the horn with every bounce.]]>
   <pubDate>Wed, 23 Jun 2010 16:28:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=10775#10775</guid>
   <title>Pet Peeve - pun intended : For the most part I have found...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=10766#10766</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=547" rel="nofollow">mountain mist</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 23 Jun 2010 at 8:38am<br /><br />For the most part I have found that campers are really the greatest people AND also most of the time they come with some animal or the other. They just seem to be that kind of people.<DIV>When we have left our Schnauzer/s behind, it was in a coach, with ac on and All the windows covered. Unless someone knocked on the door or another dog barked (the first dog barks and all the other dogs bark at THAT dog!) all was quiet on the home front.&nbsp; We tested it often by driving off and coming right back , but not checking in. Just sat in the car for a while. Then opened up and gave her an "attagirl" and treat. Also, I am a friendly sort and spoke with a nearby camper, telling them we were leaving and if the dog barked ( and fitting in with the above reasons) for other reasons that I needed to know and would plan differently. We have a friend who had a Scottie that found out she could stand with her feet on the horn and when she barked the horn would blow. Since all of us were not gone long(and might have seemed long to everyone else), just leaving campground and going home to shower and pick up mail, the campers were rolling around laughing! Give an animal a tool!</DIV>]]>
   <pubDate>Wed, 23 Jun 2010 08:38:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=10766#10766</guid>
   <title>Pet Peeve - pun intended : We use an ex-pen to keep our dogs...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=10764#10764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=481" rel="nofollow">jjbescher</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 23 Jun 2010 at 8:21am<br /><br />We use an ex-pen to keep our dogs next to our rpod.&nbsp; It takes a little bit to set-up and take down, but gives them the freedom to roam around.&nbsp; It has taken a couple of tries to get it to the point where the dogs can not escape(my little one is an escape artist, I even had to made mods to the tent end of my camper to keep her in).&nbsp; I will still be modifying my set-up to make sure they stay in.&nbsp; When we leave, they either go with us or in the camper.&nbsp; The longest they are in the camper by themselves is when we go to dinner.]]>
   <pubDate>Wed, 23 Jun 2010 08:21:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=10764#10764</guid>
   <title>Pet Peeve - pun intended : Agree with all of the above! We...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9736#9736</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=462" rel="nofollow">sylviablue</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 21 Feb 2010 at 12:04pm<br /><br />Agree with all of the above!&nbsp; We have a wonderful good natured dog but would not let him run free in a campground.&nbsp; Dangerous for him if nothing else.&nbsp; <br>We always pick up after our dog unless we're out in the woods somewhere.&nbsp;&nbsp; <br>A constantly yapping dog can make life miserable and I feel bad for the dog at the same time.<br><br>]]>
   <pubDate>Sun, 21 Feb 2010 12:04:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9736#9736</guid>
   <title>Pet Peeve - pun intended : I have seen dogs that can reach...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9733#9733</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=410" rel="nofollow">TerryM</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 20 Feb 2010 at 7:56pm<br /><br />I have seen dogs that can reach as far as 1/2 way across the road.&nbsp; These are the type of people that was mentioned above.&nbsp; The rules are for "those stupid people, not me".&nbsp; <br><br>Then there are the people that leave Precious in their RV for the day while they go running around.&nbsp; So the dog starts barking and never stops.&nbsp; Both of these situations can just plain kill a good weekend.<br><br>Terry<br>]]>
   <pubDate>Sat, 20 Feb 2010 19:56:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9733#9733</guid>
   <title>Pet Peeve - pun intended :         This is Panzer....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9732#9732</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=448" rel="nofollow">Brin</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 20 Feb 2010 at 4:13pm<br /><br /><img src="http://i920.photobucket.com/albums/ad50/obxkykr/PanzerandRpod.jpg" border="0" /><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>This is Panzer.&nbsp;&nbsp; She loves the Rpod and would rather sleep in it in the evening than sit around the campfire.&nbsp;&nbsp;&nbsp; At this site we were boondocking by ourselves in a field.&nbsp; </DIV>]]>
   <pubDate>Sat, 20 Feb 2010 16:13:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9732#9732</guid>
   <title>Pet Peeve - pun intended : We also restrain our dog in a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9731#9731</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=448" rel="nofollow">Brin</a><br /><strong>Subject:</strong> 1121<br /><strong>Posted:</strong> 20 Feb 2010 at 3:57pm<br /><br />We also restrain our dog in a similar manner and do not leave her tied out unattended at all.&nbsp;&nbsp; I have not had problems with her in a camping situation but since she can be dog aggressive in some situations (when she feels threatened by other dogs in close proximity) it is always in my mind that she must be under my control at all times.&nbsp;&nbsp; As she is a stafforshire bull terrier (but very petite at 45lbs) we have encountered parks that state "no aggressive breeds" and have elected to not test their rules.&nbsp;&nbsp; It is unfortunate that others have caused them to need these rules.&nbsp; My dog is extremely friendly and submissive to people and I try to keep her out of situations that she may feel threatened by other dogs as this has contributed to a well deserved fear on her part (she has been attacked previously).&nbsp;&nbsp; We often like to hike with her and have never had problems on a trail with her with dogs passing us by (we always step off the trail and make her sit stay to allow others to pass) but have had problems with others with loose dogs that approach.&nbsp;&nbsp;&nbsp; I have to say that it is often the dogs that owners cannot seem to control well either on or off lead that give us the most problems.&nbsp; The dogs are in control/not the owners.&nbsp;&nbsp; As a professional in the animal field, I recognize that we cannot predict our pet's behaviors in all situations and need to assure that everyone is going to be safe.&nbsp;&nbsp; At one of our last parks, the park host seemed surprised that we picked up after her--so I guess that is unusual for the average pet owner.&nbsp;&nbsp;&nbsp; I am not really surprised at this as people often have no control over their children much less their pets.&nbsp;&nbsp;&nbsp;&nbsp; I still find that I like my dog better than most people that I have met.&nbsp; ]]>
   <pubDate>Sat, 20 Feb 2010 15:57:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1121&amp;PID=9731#9731</guid>
