  <title>R-pod Owners Forum : Watching movies</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Watching movies</description>
  <pubDate>Thu, 29 Oct 2026 16:03:34 +0000</pubDate>
  <lastBuildDate>Thu, 21 Sep 2017 11:49:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=10690</WebWizForums:feedURL>
   <title>Watching movies :   Originally posted by PodizziThanks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99842#99842</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 10690<br /><strong>Posted:</strong> 21 Sep 2017 at 11:49am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Podizzi</strong></em><br /><br />Thanks for help. &nbsp;Do you know if there is a way to use blue tooth to connect to Jamison CD/stereo and then display on tv? &nbsp;I am able to connect blue tooth to Jamison but unable to display on tv. &nbsp;</td></tr></table><div><br></div><div>If you are talking about passing audio from the movie you are watching on your TV, you simply use a audio cable (mini-mini) from headphone jack on TV (mine has one) to AV-in jack on Jensen stereo. You can also do same from iPad, phone or laptop.</div><div><br></div><div>fred</div>]]>
   <pubDate>Thu, 21 Sep 2017 11:49:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99842#99842</guid>
   <title>Watching movies : No. Bluetooth is audio only. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99841#99841</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 10690<br /><strong>Posted:</strong> 21 Sep 2017 at 11:26am<br /><br />No. Bluetooth is audio only.]]>
   <pubDate>Thu, 21 Sep 2017 11:26:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99841#99841</guid>
   <title>Watching movies : Thanks for help. Do you know if...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99840#99840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7251" rel="nofollow">Podizzi</a><br /><strong>Subject:</strong> 10690<br /><strong>Posted:</strong> 21 Sep 2017 at 11:21am<br /><br />Thanks for help. &nbsp;Do you know if there is a way to use blue tooth to connect to Jamison CD/stereo and then display on tv? &nbsp;I am able to connect blue tooth to Jamison but unable to display on tv. &nbsp;]]>
   <pubDate>Thu, 21 Sep 2017 11:21:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99840#99840</guid>
   <title>Watching movies : Probably the easiest is the lightning...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99837#99837</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 10690<br /><strong>Posted:</strong> 21 Sep 2017 at 10:03am<br /><br /><div>Probably the easiest is the lightning AV adapter:</div><div><br></div><div><a href="http://www.amaz&#111;n.com/Apple-Lightning-Digital-Adapter-MD826AM/dp/B009WHV3BM" target="_blank">https://www.amazon.com/Apple-Lightning-Digital-Adapter-MD826AM/dp/B009WHV3BM</a></div><div><br></div><div>Other methods depend on wether or not you have internet connection and/or a peer-to-peer Airplay device like a later model Apple TV (which does not require internet). Some use their phone as a hotspot to create a network for ATV, Amazon Fire (stick) or Google Chromecast. You could use a travel router and setup a local network also. If you do use a mobile hotspot, be aware of data usage.</div><div><br></div><div>I have tried all of the above. The most reliable is a hardwire connection.</div><div><br></div><div>fred</div>]]>
   <pubDate>Thu, 21 Sep 2017 10:03:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99837#99837</guid>
   <title>Watching movies : Look for an HDMI connection. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99826#99826</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6152" rel="nofollow">Our pod</a><br /><strong>Subject:</strong> 10690<br /><strong>Posted:</strong> 20 Sep 2017 at 11:31pm<br /><br />Look for an HDMI connection. ]]>
   <pubDate>Wed, 20 Sep 2017 23:31:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99826#99826</guid>
   <title>Watching movies : Trying to watch movies on my iPad...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99825#99825</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7251" rel="nofollow">Podizzi</a><br /><strong>Subject:</strong> 10690<br /><strong>Posted:</strong> 20 Sep 2017 at 10:04pm<br /><br />Trying to watch movies on my iPad on the 179 tv monitor. &nbsp;Is this possible and what are steps to do it? &nbsp;Do I need a hard connection from iPad to tv? &nbsp;]]>
   <pubDate>Wed, 20 Sep 2017 22:04:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10690&amp;PID=99825#99825</guid>
