  <title>R-pod Owners Forum : Where toJack 179 to change tire</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Where toJack 179 to change tire</description>
  <pubDate>Sun, 04 Oct 2026 03:01:32 +0000</pubDate>
  <lastBuildDate>Sat, 16 Dec 2017 13:40:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=10456</WebWizForums:feedURL>
   <title>Where toJack 179 to change tire :   Originally posted by mcarter+1,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102987#102987</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6857" rel="nofollow">geewizard</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 16 Dec 2017 at 1:40pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by mcarter</strong></em><br /><br />+1, right under the riser bracket.</td></tr></table><br><br>ditto<br>]]>
   <pubDate>Sat, 16 Dec 2017 13:40:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102987#102987</guid>
   <title>Where toJack 179 to change tire : Your right, the levitationizers...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102973#102973</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=3367" rel="nofollow">funks</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 15 Dec 2017 at 5:32pm<br /><br />Your right, the levitationizers on Amazon are expensive but well worth it.<img src="https://www.rpod-owners.com/smileys/smiley36.gif" border="0" alt="LOL" title="LOL" />]]>
   <pubDate>Fri, 15 Dec 2017 17:32:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102973#102973</guid>
   <title>Where toJack 179 to change tire : Hi from Bill. Both FR &amp; Lippert...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102969#102969</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7323" rel="nofollow">HARLEYULTRA</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 15 Dec 2017 at 4:13pm<br /><br />Hi from Bill. Both FR & Lippert tell you different things. You are right you jack under the bracket & put a jack stand between the jack & tire while you do service work & you can relieve pressure on the jack.]]>
   <pubDate>Fri, 15 Dec 2017 16:13:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102969#102969</guid>
   <title>Where toJack 179 to change tire : +1, right under the riser bracket....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102968#102968</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 15 Dec 2017 at 3:47pm<br /><br />+1, right under the riser bracket.]]>
   <pubDate>Fri, 15 Dec 2017 15:47:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102968#102968</guid>
   <title>Where toJack 179 to change tire : That is the best spot that I could...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102966#102966</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 15 Dec 2017 at 2:04pm<br /><br />That is the best spot that I could find. You should have received a PM with the specific link showing the jacking block I made to best jack up the pod without putting pressure on the axle tube.]]>
   <pubDate>Fri, 15 Dec 2017 14:04:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102966#102966</guid>
   <title>Where toJack 179 to change tire :  Hello,  With regards as to where...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102959#102959</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7877" rel="nofollow">PracticalPodder</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 15 Dec 2017 at 10:38am<br /><br /><br />Hello,<br /><br />With regards as to where to PLACE the jack on an Rpod, in my case a 2018 178, should the jack be placed only on the bracket in the attached picture?<br /><br />Haven't quite figured out how to get the picture to appear (I might not be able to link to OneDrive). Copy and paste these links into your browser.<br /><br />Sigh, these links may not work.  Let me know.<br /><br />https://1drv.ms/i/s!AoFQRUJHVZ-Rth8cYS-SKpw_6vrN<br /><br />Here is SteveH's homemade jacking block<br /><br />https://1drv.ms/i/s!AoFQRUJHVZ-RtiCIeE8jistTFQUv<br /><br />Or in the forum<br /><br />http://www.rpod-owners.com/forum_posts.asp?TID=7712&PID=82715&title=our-escapod-mods#82715<br />]]>
   <pubDate>Fri, 15 Dec 2017 10:38:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=102959#102959</guid>
   <title>Where toJack 179 to change tire : If you jack where the axle attaches...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97618#97618</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 07 Aug 2017 at 1:25pm<br /><br />If you jack where the axle attaches to the frame, the axle won't bend. I assume the axle is capable of holding up that much weight without being crushed, which is the only way it could be damaged.]]>
   <pubDate>Mon, 07 Aug 2017 13:25:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97618#97618</guid>
   <title>Where toJack 179 to change tire : I position the jack under the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97488#97488</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4133" rel="nofollow">sailor323</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 4:07pm<br /><br />I position the jack under the riser bracket]]>
   <pubDate>Sat, 05 Aug 2017 16:07:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97488#97488</guid>
   <title>Where toJack 179 to change tire : I&amp;#039;ve been jacking on the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97473#97473</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7384" rel="nofollow">spydie</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 9:24am<br /><br />I've been jacking on the axel (same type as used on the Pod, Torsion axels) for 20 years. &nbsp;I see no reason not to. &nbsp;The axel is plenty strong enough for these light trailers and that used to be the recommended spot even according to the axel manufacturer. &nbsp;My Pod is in the shop right now, so is all my paperwork/manuals (in the camper) but as soon as I get it back, I'll check where I saw the jack points in my manual. &nbsp;I could swear it said to jack on the axel. &nbsp;But I might have dreamed that!]]>
   <pubDate>Sat, 05 Aug 2017 09:24:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97473#97473</guid>
   <title>Where toJack 179 to change tire : My mechanic uses a floor jack...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97471#97471</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 8:55am<br /><br />My mechanic uses a floor jack in the spot Stephen H suggests when he does the inspection on the bearing and tires etc<div>Seems to be good. No problems in 7 plus years of rpods</div>]]>
   <pubDate>Sat, 05 Aug 2017 08:55:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97471#97471</guid>
   <title>Where toJack 179 to change tire : hmmmmm, my dealer jacks on the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97465#97465</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 7:47am<br /><br />hmmmmm, my dealer jacks on the axle about where it meets the frame. I saw this and said" i thought your not supposed to jack on the axle" , he said, " i jack close to where the axle meets the frame" as if that makes a difference. He used no block, just a normal floor jack. Doesnt mean its right, just what he did&nbsp;<div><br></div>]]>
   <pubDate>Sat, 05 Aug 2017 07:47:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97465#97465</guid>
   <title>Where toJack 179 to change tire : For what it&amp;#039;s worth, the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97464#97464</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 6:48am<br /><br />For what it's worth, the documentation that comes with the Pod does indeed say not to use the frame as a jack point, and the documentation for the axle says not to use it either.&nbsp; I guess the best thing to do is never have a flat. Or buy one of the 12v RV levitationizers available on Amazon, but they're expensive....<br><br>StephenH's suggestion for a block to spread the weight a bit is good, and I agree, jacking the axle under where it attaches to the frame is best.<br><br>TT<br>]]>
   <pubDate>Sat, 05 Aug 2017 06:48:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97464#97464</guid>
   <title>Where toJack 179 to change tire :   Originally posted by spydie  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97463#97463</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 6:46am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by spydie</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by HARLEYULTRA</strong></em><br /><br />Hi Friends. They say do not jack on axle or frame.Where do you jack &amp; put a jack stand so you can change tire,do bearings, adjust brakes ect. Bill</td></tr></table><div><br></div><div>Who said not to jack on the axel? &nbsp;My instructions say (and I've done it many times on other trailers built just like this one with the same axel) to jack on the axel.</div></td></tr></table><br><br>The axle manufacturer says not to jack on the axle, the frame manufacturer says not to jack on the frame.. It's in the Pod paperwork.. <br>]]>
   <pubDate>Sat, 05 Aug 2017 06:46:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97463#97463</guid>
   <title>Where toJack 179 to change tire : +1   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97461#97461</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1100" rel="nofollow">Leo B</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 5:59am<br /><br />+1]]>
   <pubDate>Sat, 05 Aug 2017 05:59:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97461#97461</guid>
   <title>Where toJack 179 to change tire : Look in my mods and you will see...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97458#97458</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 05 Aug 2017 at 12:13am<br /><br />Look in my mods and you will see a block I made for jacking that cradles the shape of the axle but the weight is on the brackets that mount the axle to the riser block. That avoids any problems. I recently used it to lube my hubs.<br>]]>
   <pubDate>Sat, 05 Aug 2017 00:13:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97458#97458</guid>
   <title>Where toJack 179 to change tire :   Originally posted by HARLEYULTRAHi...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97453#97453</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7384" rel="nofollow">spydie</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 04 Aug 2017 at 10:30pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by HARLEYULTRA</strong></em><br /><br />Hi Friends. They say do not jack on axle or frame.Where do you jack &amp; put a jack stand so you can change tire,do bearings, adjust brakes ect. Bill</td></tr></table><div><br></div><div>Who said not to jack on the axel? &nbsp;My instructions say (and I've done it many times on other trailers built just like this one with the same axel) to jack on the axel.</div>]]>
   <pubDate>Fri, 04 Aug 2017 22:30:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97453#97453</guid>
   <title>Where toJack 179 to change tire : Hi Friends. They say do not jack...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97449#97449</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7323" rel="nofollow">HARLEYULTRA</a><br /><strong>Subject:</strong> 10456<br /><strong>Posted:</strong> 04 Aug 2017 at 7:52pm<br /><br />Hi Friends. They say do not jack on axle or frame.Where do you jack & put a jack stand so you can change tire,do bearings, adjust brakes ect. Bill]]>
   <pubDate>Fri, 04 Aug 2017 19:52:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10456&amp;PID=97449#97449</guid>
