Roof to side joint problem
URL: http://www.rpod-owners.com/forum_posts.asp?TID=9609
Printed Date: 16 Jul 2025 at 5:18am
Topic: Roof to side joint problem
Posted By: Elenaron
Subject: Roof to side joint problem
Date Posted: 02 Apr 2017 at 9:24pm
I have noticed that the plastic bead that covers the joint between the roof and the trailer's sides is cracking and breaking down, especially in the back where the roof curves down and becomes the back.
I can see the screws holding the joint together have become exposed, and I'm concerned about water leaking in through them.
Can this plastic bead be replaced?
Is a quick fix for now to add silicone caulking on this joint, especially over and around the screw heads?
We have a 2014 RPod 178
2014 R-Pod 178
2014 Ford F-150
Posted By: StephenH
Date Posted: 02 Apr 2017 at 10:12pm
We had that done under warranty just before it expired. Your dealer would likely sell you the strip material or you can do it yourself. The vinyl strip is available on eTrailer as https://www.etrailer.com/RV-Exterior/Camco/CAM25212.html - Camco RV Vinyl Trim Insert-Black . I'm not sure of the width. I saw both 1" and 3/4" listed.
Posted By: furpod
Date Posted: 03 Apr 2017 at 8:42am
It's not a "seal" it's just a piece of trim that covers the screw heads for appearance. Takes minutes, and a couple dollars to replace.
Posted By: Elenaron
Date Posted: 05 Apr 2017 at 12:58pm
Thanks for your replies.
I'm not sure that this plastic strip is strictly cosmetic. I'm finding some of the exposed screw heads are badly rusted. And, I'm not sure that water isn't working its way inside along them.
2014 R-Pod 178
2014 Ford F-150
Posted By: StephenH
Date Posted: 05 Apr 2017 at 4:23pm
I think it would be nice if Forest River used Stainless Steel screws in places like the seams that are exposed to water and subject to corrosion.
Posted By: fwunder
Date Posted: 05 Apr 2017 at 5:17pm
Yes, it would be nice if they used a lot more stainless and aluminum and magnesium. I'm rapidly beginning to appreciate a seamless fiberglass rv hull...
In the meantime, while I save for my Ollie, I'm replacing the track and keder screws with stainless screws dipped in epoxy. The screws are about $0.20 a piece at my local True Value. If I could find them in bulk, I'm sure they would be a lot cheaper.
Posted By: lostagain
Date Posted: 05 Apr 2017 at 5:44pm
I've been using stainless steel screws on all work I've done where there is water exposure.  Also, sealing the screws with a bedding compound, such as 3M 5200, helps keep the water out.  ....something I learned from my sail boat days.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Posted By: Elenaron
Date Posted: 05 Apr 2017 at 9:49pm
Furpod,
Does the plastic strip slide in the slot from one end to the other (like a tent pole) or does it get tucked in side to side.
Thanks!
2014 R-Pod 178
2014 Ford F-150
Posted By: Elenaron
Date Posted: 05 Apr 2017 at 9:57pm
Fwunder,
I need to replace some of the screws. Can they be just be scewed out and the new ones screwed back in? Do you know the right size? (It looks like in your picture your new one is longer that the original - does that matter?) Can you replace the screws without replacing the track?
Thanks!
2014 R-Pod 178
2014 Ford F-150
