Breakaway battery charge?
URL: http://www.rpod-owners.com/forum_posts.asp?TID=9590
Printed Date: 28 Jun 2025 at 5:43am
Topic: Breakaway battery charge?
Posted By: GLBCamper
Subject: Breakaway battery charge?
Date Posted: 31 Mar 2017 at 11:34am
I recently saw a checklist that said to check the breakaway battery charge level before each trip. I didn't know the breakaway switch had it's own battery. Where is it? How do I check the charge? All I see is the little box that the pin goes in.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Posted By: StephenH
Date Posted: 31 Mar 2017 at 11:35am
The breakaway switch does not have a separate battery. The R-Pod's battery supplies the power.
Date Posted: 31 Mar 2017 at 11:44am
That's what I always assumed. But in looking on eTrailer, the "breakaway kits" all include a charger (I assume to keep a dedicated breakaway battery charged?)
Old: 2014 177 HRE
2016 F150 4x4 Sport
Posted By: StephenH
Date Posted: 31 Mar 2017 at 12:47pm
The R-Pod's switch is OEM. The "breakaway kits" on eTrailer are aftermarket. They don't necessarily have the same specificatons.
Posted By: CharlieM
Date Posted: 31 Mar 2017 at 1:14pm
Some campers and some utility trailers have a separate battery. The Pod does not. It uses the main battery. The E-trailer kits are intended for those that have the separate battery. Just check the main battery on the Pod for water level and make sure it is fully charged overnight before you leave.
Date Posted: 31 Mar 2017 at 3:41pm
Thanks so much.
Old: 2014 177 HRE
2016 F150 4x4 Sport
