Tire sensors
URL: http://www.rpod-owners.com/forum_posts.asp?TID=9349
Printed Date: 22 May 2025 at 2:51am
Topic: Tire sensors
Posted By: dlighter
Subject: Tire sensors
Date Posted: 18 Feb 2017 at 7:56am
Does anyone have a recommendation for tire pressure sensors? First single axle camper and I want to make sure there aren't any issues.
2010 Toyota Tacoma
2017 Rpod 180
Buried under 3' of snow. Camping season can't get here soon enough!
Posted By: Podster
Date Posted: 18 Feb 2017 at 11:32am
I check my tires regularly and sensors won't prevent a blowout so I don't use them.
Cliff & Raelynn
Ranger 4.0/178
Posted By: Our pod
Date Posted: 18 Feb 2017 at 11:44am
I can see the pod tires from my side-view mirrors, and check them at each stop (visually). I will check the air pressure periodically as well.
Life is good.
Posted By: Leo B
Date Posted: 18 Feb 2017 at 12:22pm
I agree with both of the above.
Posted By: mcarter
Date Posted: 18 Feb 2017 at 2:45pm
Me too, not sure what the gain is from TPS, I also monitor tire pressure and bearing heat, make sure everything is torqued, maintenance done,tires are in good shape, balanced and went with D rated tires. Important to not exceed speed rating. TPS is just going to tell me I lost or am losing tire pressure, in case of a blowout I think I would probably already know that.
Posted By: jato
Date Posted: 18 Feb 2017 at 6:44pm
Agree with all you above posters.  One time I had a tire that I could visually see via the rear view mirror was a bit low.  I stopped and checked both tires even though they were warm and noted a 4 psi difference between the two tires.  Took out my bicycle tire pump and pumped it up to match the other and went on my way.  When I got to the campground I took a closer look at the tire because I knew it was good when I left in the morning, you guessed it, I picked up a 2" long roofing nail in the tread, easy fix at the filling station.  Got 20,000 plus miles on them and then replaced as they were 6 years old last spring.
Posted By: ribet
Date Posted: 19 Feb 2017 at 7:23pm
Tire pressure monitoring valve stem caps are cheep. Available in different pressures levels. Usually sell for under $10 fore four caps. A quick check. Turn red if tire pressure is under the caps pressure rating.
