2017 179 ac unit
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8890
Printed Date: 26 Jun 2025 at 11:56am
Topic: 2017 179 ac unit
Posted By: Mafghine
Subject: 2017 179 ac unit
Date Posted: 08 Oct 2016 at 7:49pm
Last night we fired it up for the first time for full force ac night, (we like it cold). I set it to 55 on the thermostat and it was blowing hard and cold, however it started sounding like it was wanting to cycle due to reaching 55 degrees. But the turn off lasted only 2 secs then it would power back on, then 2-3 mins later it would do it again.
My question is, is it just turning off the ac during the 2-3 mins and just running the fan/blower?
I would like a setting of just [on] [desired temp] [off]  but it just has desired temp and off. I am plugged into a 30 amp rv outlet that my electrician installed other day.
thank you for your continued help with our new pod.
edit: title was 177, its 179 model
Posted By: StephenH
Date Posted: 09 Oct 2016 at 4:01pm
We see that also. The cycling seems to be switching the fan from low to high speed. You can manually switch from auto to low or high speed and the cycling won't happen. OTOH, when set to low or high speed, the fan will run all the time, whether needed or not. On auto, the fan will shut off also when it isn't needed.
Try adjusting the vents on the AC so that the air does not blow on or near the thermostat. That may help also.
Posted By: Mafghine
Date Posted: 10 Oct 2016 at 8:15am
Awesome idea on  not blowing on the thermostat, ty.
