Two 6 - volt battery, question
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8601
Printed Date: 25 Jun 2025 at 12:35pm
Topic: Two 6 - volt battery, question
Posted By: Patriot Dave
Subject: Two 6 - volt battery, question
Date Posted: 16 Aug 2016 at 1:38pm
I have installed two golf cart 6 volt batteries.
With that said; Is it safe to take them lower than 50% discharge. Reading my digital volt meter at what point is a good number at which I should start charging.
Thanks
Dave
Dave & Joyce
Posted By: WillThrill
Date Posted: 16 Aug 2016 at 3:03pm
Thanks
Dave
Dave,
Golf cart batteries cycle better than do the more common 12 volt marine batteries, but taking them below 50% on a regular basis will still reduce their lifespan.
At 12.2 volts, your batteries are roughly at 50% charge, so they should be recharged at that point, if not before.
Percentage of Charge12 Volt Battery Voltage24 Volt Battery VoltageSpecific Gravity
10012.7025.401.265
9512.6425.251.257
9012.5825.161.249
8512.5225.041.241
8012.4624.921.233
7512.4024.801.225
7012.3624.721.218
6512.3224.641.211
6012.2824.561.204
5512.2424.481.197
5012.2024.401.190
4512.1624.321.183
4012.1224.241.176
3512.0824.161.169
3012.0424.081.162
2512.0024.001.155
2011.9823.961.148
1511.9623.921.141
1011.9423.881.134
511.9223.841.127
Discharged11.9023.801.120
https://www.emarineinc.com/Batteries-Maintenance-101
2014 Hood River 177
2005 GMC Envoy XL
Date Posted: 16 Aug 2016 at 5:29pm
Great and Thanks for the info, it is much appreciated.
Dave & Joyce
Date Posted: 16 Aug 2016 at 6:48pm
Giving it some more thought; there is no difference between 1 - 12 volt verses 2 - 6 volts?
Dave & Joyce
Posted By: CharlieM
Date Posted: 16 Aug 2016 at 9:40pm
The difference is two 6V batteries will generally give you much more capacity than a single 12V. Even two 12V batteries of the type usually employed (GP24, 27) are less capacity. And it's a fact that individual 2V cells like to be used in series, not parallel. It helps in equalizing the loads.
Posted By: techntrek
Date Posted: 16 Aug 2016 at 10:02pm
Either way it is a 12 volt system and the batteries function the same, just with more lead mass with the golf cart batts, which gives you more available energy.
The rule of thumb is stay above 50% DOD most of the time, an occasional dip below that is ok but never go below 35% DOD.  This is followed with most off-grid solar home systems.
Date Posted: 17 Aug 2016 at 6:39am
Thanks for the reply and I better now know or understand.
Dave & Joyce
Date Posted: 17 Aug 2016 at 6:41am
Thanks for the reply.
DOD? Meaning?     _________ of Discharge
Dave & Joyce
Posted By: JandL
Date Posted: 17 Aug 2016 at 9:04am
DOD, short for the Depth of Discharge, is used to describe how much the battery is discharged
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Date Posted: 17 Aug 2016 at 11:02am
OK, Thanks
Dave & Joyce
Date Posted: 17 Aug 2016 at 8:30pm
Inversely, SOC is state of charge.  20% DOD = 80% SOC.  Sorry I didn't decode DOD earlier.
Date Posted: 18 Aug 2016 at 1:55am
Thanks Again
Dave & Joyce
