Toilet today
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8504
Printed Date: 20 Jul 2025 at 8:38am
Topic: Toilet today
Posted By: Countrified
Subject: Toilet today
Date Posted: 03 Aug 2016 at 12:13pm
The toilet in our 2014 R-pod seems to be plugged. Liquids will go down but not solids. I didn't think there was anything that could block it. I emptied the black water tank and I tried poking a stick down into the tank. It will go all the way into the tank and it seems to be clear but same results. Ever have this happen? It's the side lever trigger and I can see the gate open.
Posted By: JandL
Date Posted: 03 Aug 2016 at 8:24pm
How much water did you have in the bowl before you pulled the lever? you can pull the lever part way to add some water to the bowl, when you pull the lever all the way the valve opens up and the water you added to bowl pulls every thing down with it. If it turns out to be a clog in the pipe a long handle toilet brush works very well at cleaning the pipe out
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Posted By: techntrek
Date Posted: 03 Aug 2016 at 9:52pm
Don't forget the 2/3 rule.  For #2 visits to the toilet the bowl should be 2/3 full of water, and the black tank should be 2/3 full before emptying it.
If the solids aren't going down even with a full bowl of water, you do have a clog in the pipe.
