Roof Caulking
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8416
Printed Date: 24 Jun 2025 at 10:10pm
Topic: Roof Caulking
Posted By: 4runninpod
Subject: Roof Caulking
Date Posted: 18 Jul 2016 at 7:39pm
I finally had a chance to look over the roof on the pod and found a few things I am concerned about. Not sure if it is suppose to look like this or not? What kind of caulking does everyone use?
Posted By: Podster
Date Posted: 19 Jul 2016 at 9:37am
Yes, the manufacture suggest inspection and resealing as needed every 90 days. You can wipe those areas with acetone on a rag then reseal with self leveling dicor for everything on the roof. I use high quality silicone on everything else.
Cliff & Raelynn
Ranger 4.0/178
Posted By: john in idaho
Date Posted: 19 Jul 2016 at 10:32am
I am not familiar with dicor.
Posted By: furpod
Date Posted: 19 Jul 2016 at 10:35am
The area on the trim, use a good quality silicone caulk. On the roof around the light bar leading edge, use a "self leveling lap sealant". The factory uses Dicor brand. Generally, the Lap Sealant is good nearly forever. Silicone, not so long.
Lap sealant WILL stick to itself, so precleaning efforts can be minimal, the silicone though.. it won't, so you need to clean those areas very well.
Posted By: furpod
Date Posted: 19 Jul 2016 at 10:38am
http://www.campingworld.com/shopping/item/dicor-self-leveling-lap-sealant-white/32125 - Dicor Lap Sealent
Date Posted: 19 Jul 2016 at 4:40pm
Great thanks, obviously the previous owner didn't check it. Good thing I have a shop big enough to store it inside.
