Shower facuet question
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8344
Printed Date: 24 Jun 2025 at 8:50am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Shower facuet question
Posted By: Jewel59
Subject: Shower facuet question
Date Posted: 07 Jul 2016 at 11:06am
I have a new 180 with a separate shower. I've had it out on five trips so far and love it. I've noticed that the shower facuet assembly has some play in it and the caulking has come loose on the top of the assembly. It's possible it was always loose but the caulking kept it from being visible. My question is, is it supposed to have some play (maybe this helps keep it safe while trailing over bumps etc.), or should it be tightened? There is no obvious easy to way to tighten it based on what I can see. I'm getting ready for another trip and don't have time to take it in right now. I do use the shower (and love it). Hope this makes sense.
Posted By: furpod
Date Posted: 07 Jul 2016 at 11:40am
It is held in place from behind, there should be an access panel on the wall behind it. Then reach in and tighten the big nut things holding it in place. Then clean up the caulk and redo it.
Posted By: Jewel59
Date Posted: 07 Jul 2016 at 1:34pm
THANKS! I bet that's it. There is a metal rectangle that this screwed to the wall behind it. I wondered why that was there. I will check on this when I get home.
Posted By: Jazz trumpet
Date Posted: 08 Jul 2016 at 1:20pm
Read this tip and will use the information. Thanks
------------- John and Marilyn
2016 Rpod 180
2001 Chevrolet Suburban
