Hinged RP-179 fridge panel
URL: http://www.rpod-owners.com/forum_posts.asp?TID=8004
Printed Date: 23 Jun 2025 at 4:41am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Hinged RP-179 fridge panel
Posted By: TheBum
Subject: Hinged RP-179 fridge panel
Date Posted: 23 May 2016 at 3:31pm
I know some people here have come up with some imaginative ways of replacing the panel below the fridge on the 179 that comes loose as items shift in transit.
I decided to keep the panel and use a different attachment method. I attached two self-closing cabinet hinges that allow the panel to swing back as items shift into it. Also, retrieving items that have fallen behind the panel is a lot easier.
[TUBE]xSvK4T7Yf84[/TUBE]
Posted By: sailor323
Date Posted: 23 May 2016 at 4:35pm
Posted By: StephenH
Date Posted: 23 May 2016 at 8:19pm
My solution was to get some anchors, the kind with the white plastic "wings" that you insert, then use a plug to expand the "wings." I used screw caps and washers to dress it up.
The anchors in the frame hold much more securely than the original screws in the aluminum frame, yet are flexible enough to give a little if it encounters resistance. I had originally thought about using hinges, but couldn't quite figure out how to make it work like I wanted. Your way is good if it encounters resistance while retracting the slide-out. I wanted it to be able to flex when extending as well, but couldn't quite figure out how to do that.
------------- StephenH
Posted By: TigerPawd
Date Posted: 24 May 2016 at 5:29pm
We went with hinges. A good feature is that when we break camp and something has fallen behind (it happens), no damage occurs as the slide closes.
------------- Joan, Jerry and the two Pugs
2015 R-Pod 179
