SEWER HOSE CARRIER
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7874
Printed Date: 22 Jun 2025 at 9:29pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: SEWER HOSE CARRIER
Posted By: hogone
Subject: SEWER HOSE CARRIER
Date Posted: 04 May 2016 at 6:56pm
sorry to rehash. so exactly where do you hang the new sewer hose tube; just recieved the 64"er. hogone
------------- Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted By: furpod
Date Posted: 04 May 2016 at 7:06pm
I went crosswise, Used a piece of angle for a "bracket on one side, just into the bottom of the frame on the other.
Posted By: TheBum
Date Posted: 05 May 2016 at 10:29am
Or, you could do like I did with my 60" and mount it to the frame in the rear. I used 1/8" thick mending plates and bolts all the way through the 1.5" square piece of frame tubing back there. Whatever you have attached to the hitch receiver (spare tire, bike rack, etc.) acts as a central support.
Posted By: furpod
Date Posted: 05 May 2016 at 4:38pm
Originally posted by TheBum
Or, you could do like I did with my 60" and mount it to the frame in the rear. I used 1/8" thick mending plates and bolts all the way through the 1.5" square piece of frame tubing back there. Whatever you have attached to the hitch receiver (spare tire, bike rack, etc.) acts as a central support. |
My worry with that is it that hangs pretty low, Pods scrape their rear stabilizers pretty regularly..
Posted By: TheBum
Date Posted: 05 May 2016 at 6:18pm
It's well above the stabilizers. The spare tire carrier hitch bar goes under it. It almost looks like a bumper.
Posted By: furpod
Date Posted: 05 May 2016 at 6:54pm
It's well above the stabilizers. The spare tire carrier hitch bar goes under it. It almost looks like a bumper. |
Sounds good then.. I was thinking it was below that hitch..
Posted By: hogone
Date Posted: 06 May 2016 at 6:04am
i will check that location out, thanks all. hogone
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted By: hogone
Date Posted: 06 May 2016 at 6:58am
thebum: it just got light enough to take a peak. just to clarify; did you attach the mending plates to the frame tubing then attach the sewer hose tube to the mending plates? did you center it and if so there is enough room to open the ends of the hose tube to access the hose? hope that all makes sense!! hogone
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
