Better than new 2016 R-Pod 179 with two interior floor plan options. Interior is pebble, has factory layout and an additional layout. You can have large U shape dinette that converts to bed and use couch as a long couch for more room. See pictures for options, you can use any style depending on your trip. This R-Pod has been out about 5 times, everything works perfectly. Still looks new, smells new, no smoking or pets have been inside. The camper has also always been stored inside. Options installed after purchase from dealer.
Double propane tanks with cover and automatic change over regulator valve.
Double batteries with battery boxes and battery disconnect switch.
Digital voltage readout inside camper at control panel.
Temperature and humidity readout.
3 hinged storage compartment lids under the bed, not just one large piece of wood. Easy access for access to furnace and water pump for winterizing.
Throw carpets for both interior layouts
2 oscillating 12V fans, one at the bed and one at the couch
Removable shelves in the wardrobe
LED lights in pantry, when doors open lights come on
LED strip light over sink with matching valence, switch by the door. Very nice option.
Matching medicine cabinet with mirror
Full length mirror installed on bathroom door
Flexible shower hose and upgraded shower head
Shampoo and soap racks in the shower
Hanging broom behind shower curtain
Removed shower sink for added room (can easily be re-installed if you wish)
Window installed in the door with screen and interior shade
Fresh water drain valve accessible without crawling under trailer
Folding cup holders at the couch on both ends
Paper towel holder and storage bin at kitchen counter
Additional towel bars at kitchen and bathroom
Microwave/Convection oven never used
Stove top burners never used
TV with swivel mount to adjust up and down. Storage rack underneath for remotes etc.
R-Dome that has never been out of the bag
Axle risers for added clearance
Load range D 8ply tires, no sidewall sway, camper tows beautifully with fresh water loaded or unloaded
Exterior LED porch light can be left on all night with hardly any battery drainage
Grey water bleed off hose
Two table top options
For pictures: https://www.dropbox.com/sh/0z0f0mjmlau2z2o/AABvP9ZCkIgHnbbcpKhYo-IOa?dl=0 - https://www.dropbox.com/sh/0z0f0mjmlau2z2o/AABvP9ZCkIgHnbbcpKhYo-IOa?dl=0
This is the top of the line, first class R-Pod. Decided to buy a large truck and camper because my teenagers always want to go with us.
$16,200 OBO
Located in Loveland, OH 45140
Contact Jay by phone or email
513-200-8792
ovaltrack29@fuse.net
