Dewinterize Question
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7756
Printed Date: 22 Jun 2025 at 10:14am
Topic: Dewinterize Question
Posted By: PodDude
Subject: Dewinterize Question
Date Posted: 14 Apr 2016 at 8:04pm
I've been reading the r-pod manual thread on de-winterization - http://www.rpod-owners.com/forum_posts.asp?TID=1723&PID=14734&title=creating-an-instruction-maintanence-manual#14734 - http://www.rpod-owners.com/forum_posts.asp?TID=1723&PID=14734&title=creating-an-instruction-maintanence-manual#14734  I just bought a used pod, and they flushed the antifreeze, but did not sanitize, so I thought I'd just follow the instructions as if I were completely de-winterizing.  What I'm confused on, is it seems like you need to have certain valves in a  a certain position (winter mode?) prior to beginning, but this part isn't elaborated on. I think the purpose is you're avoiding running bleach through the hot water heater?  I have a 178 if that matters.
Posted By: CharlieM
Date Posted: 14 Apr 2016 at 9:15pm
Full disclosure: We don't winterize here in FL, and if I did, I'd clear it with an air compressor. That said, the reason for putting the valves in the "winter or bypass" position is to keep pink antifreeze from filling the water heater. Draining the WH protects it from freezing. For sanitization I see nothing wrong with allowing bleach to run through the WH. In fact I recommend it because stuff can grow in the WH and it's associated piping at an accelerated rate due to the heat. True, high heat kills some germs, but other germs and mold like a nice cozy environment. Just be sure to flush out the bleach thoroughly from all hot and cold piping. Each season I add bleach to the fresh water tank, allow it to run through the pump and cold water pipes, and let it sit for a day. Then I pump the FW tank empty through the HW piping and water heater, and let it sit another day. Then flush everything with plenty of fresh water, including the WH and FW tank. This disinfects both hot and cold water systems.
Posted By: PodDude
Date Posted: 14 Apr 2016 at 10:23pm
Thanks a lot, that's what I'll try to do this weekend then. I see you have a supercharged tacoma listed in your signature, that must be fun! Have heard of supercharged Tundra V8s but never a 4L
Posted By: CharlieM
Date Posted: 15 Apr 2016 at 8:18am
The Taco's entire life is towing the camper, except for a trip to the hardware store every other week. I added the SC to combat loss of performance at altitude. We travel a lot in the Colorado Rockies. I wanted a V8 but not a full sized pickup. The SC Tacoma was the best alternative. It works!
Posted By: techntrek
Date Posted: 15 Apr 2016 at 10:15pm
Getting the bleach-water into the WH won't hurt it.
