Chirp sound
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7622
Printed Date: 22 Jun 2025 at 4:27am
Topic: Chirp sound
Posted By: john in idaho
Subject: Chirp sound
Date Posted: 24 Mar 2016 at 11:11am
Our 2015 179 is in the barn for the winter, and plugged in. Every now and then, when I am in the barn I hear a very faint , fraction of a second, chirp coming from the vicinity of the rPod.  I can't figure out what is chirping.  Any ideas?
Posted By: Craneman
Date Posted: 24 Mar 2016 at 11:15am
Might check your batteries in smoke alarm, carbon monoxide alarm
Jo and Gary
2010 174
2011 Ford 150
Posted By: furpod
Date Posted: 24 Mar 2016 at 11:25am
99.99% answer.
Only a few things chirp like that, the 2 sensors mentioned, the propane detector if the 12v system gets low, and the fridge if the door is left open and it's turned on (some fridges beep if the selected power source isn't available also).
Posted By: Leo B
Date Posted: 24 Mar 2016 at 11:30am
Ditto, had that happen
Date Posted: 24 Mar 2016 at 11:34am
so the smoke and CO detectors are not hard wired?  I will have to go look for them as I don't know where they are.
Date Posted: 24 Mar 2016 at 12:35pm
It was the smoke detector, and it is not hard wired - needs the usual 9.6 v battery.   Now I need to go get some more so I will have a spare.   Makes me wonder if the one in my old tent trailer that I had assumed was hard wired,  had a dead battery over the winter and was never replaced.
Posted By: jato
Date Posted: 24 Mar 2016 at 5:32pm
Funny thing that you brought that up.  Checked our 177 in our horse barn and hearing the same chirping sound.  Took a minute to figure which detector it was as it would go off about every 30 seconds.  It was the carbon monoxide detector in our case, quick fix with a 9 volt battery.  Not bad in that it lasted for just over 5 years.  Hardest thing was getting to the barn, had a significant snow last night and today, near blizzard conditions now, can't hardly see anything, except white.
Posted By: techntrek
Date Posted: 24 Mar 2016 at 9:39pm
I always pull the batteries in the CO and smoke detectors over the winter.
Posted By: Leo B
Date Posted: 24 Mar 2016 at 9:43pm
Same here and always put a fresh one in at the beginning of the season.
Date Posted: 24 Mar 2016 at 10:09pm
The detector down at floor level is hard wired, I discovered.
Date Posted: 25 Mar 2016 at 10:06pm
That is the LP detector.  It uses too much power to run on a small battery.
Posted By: Leo B
Date Posted: 25 Mar 2016 at 10:09pm
The LP detectors can go bad. I had to replace ours one month after we bought our 179. Real easy to replace.
Date Posted: 26 Mar 2016 at 6:37pm
Note that all 3 detectors have expiration dates, something to keep an eye on.  When I bought my current camper 2 of the 3 detectors were expired.
Date Posted: 26 Mar 2016 at 8:01pm
3 detectors, huh? Where is the third one?
Posted By: JohnBG
Date Posted: 28 Mar 2016 at 8:39am
Depending on what model you have thy might be in slightly different locations.
The smoke detector hangs from the ceiling, ours inconveniently mounted right above the microwave/convection oven.  Runs on a 9V battery and will chirp when the battery is weak.  The cover swings off to one side where you can replace the battery.
The carbon monoxide (CO) sensor is on the wall near the ceiling above the bed.  It also runs on a 9V battery that should chirp if the battery is weak or the sensor is going bad.  They have a date stamp on them and should be replaced every 5 years, mine went bad last year as it's a 2010 model.  The whole sensor twists off from a bracket that secures it to the wall and there is a battery compartment on the back where you can remove and replace the battery.
The third sensor is a propane sensor, which is hardwired and runs off the campers big 12V battery, usually on the dinette seat about 8 inches to a foot off the ground, looks like a gray square box with a green LED on the front of it.  Ours has never chirped but alarms loud and steady.  I've found that sometimes stinky sulfur water fumes from a campsite can trip it.  It's only gone off twice and both times we had the gas tank shut off.
2010 R-Pod RP-171
2010 Honda Ridgeline TV
Date Posted: 28 Mar 2016 at 10:57am
so I changed the battery in the CO detector.  Will check for the smoke detector in the kitchen - probably change it as well.
