Sway Bar for Toyota Tacoma PreRunner V6
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7409
Printed Date: 21 Jun 2025 at 2:18pm
Topic: Sway Bar for Toyota Tacoma PreRunner V6
Posted By: OnTheRoad
Subject: Sway Bar for Toyota Tacoma PreRunner V6
Date Posted: 03 Feb 2016 at 4:37am
Hope I'm posting correctly! Instructions are a bit vague! I'd like recommendations for TT PreRunner sway bar. I have a new (to me) 178 HRE with a slight sway when on Interstate. It's manageable but think I'd have a better ride with a sway bar. Not interested in an expensive one if there is such a thing! Any suggestions? Thank you very much!
Posted By: CharlieM
Date Posted: 03 Feb 2016 at 8:58am
From personal experience with my Taco I recommend the E2 WDH from Progress Mfg. Co. and FastwaytTrailer.com. It combines weight distribution and sway control. Even on the Taco the weight distribution function greatly improves the ride, eliminating uncomfortable porpoising and bounce. Far better than friction sway control devices and no removal for backing up required.
Posted By: GLBCamper
Date Posted: 03 Feb 2016 at 11:47am
You will find many people here absolutely insist on needing a WDH. And I am sure they are the best way to go. But for many reasons, money actually being the least of which, I decided to just go with a friction sway bar for my taco and have been quite happy. I got the pro series from eTrailer for $37.95.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Posted By: CharlieM
Date Posted: 03 Feb 2016 at 12:07pm
Just to be clear I draw a distinction between "need" a WDH and "want" a WDH. There are many setups where you might not need one for safety or rating reasons, but the WDH will always improve the ride and reduce driver fatigue. Unless of course you're towing your 172 with an F350 dually Wink
Posted By: jswann
Date Posted: 03 Feb 2016 at 1:24pm
Is there any reason to get a E2 with a higher weight rating like 10,000 lb or is the 6,000 plenty ?
Posted By: CharlieM
Date Posted: 03 Feb 2016 at 2:54pm
No reason at all. With the 178 spec'd at UVW=2554# plus ball park 1000# stuff, water, propane, batteries, etc you're still well within the 6000# E2. Stiffer bars just make the ride harsher and add damage potential if you find an extreme dip.
Posted By: john in idaho
Date Posted: 03 Feb 2016 at 4:07pm
The Andersen hitch looks pretty slick.  A little more money but I like the fact that it doesn't push the tongue up in rebound.
Date Posted: 03 Feb 2016 at 4:26pm
Thanks everyone for responding so promptly with good suggestions. Onward!
Posted By: techntrek
Date Posted: 03 Feb 2016 at 7:55pm
Welcome.  I used a 6000 pound E2 with my pod and it worked well.
Posted By: Robwid
Date Posted: 03 Feb 2016 at 11:07pm
I'll echo GLBC.  I use a friction sway bar and pull with a Tacoma.  When I bought my pod the salesman had me sold on a WDH but the service manager said all I would need is the friction sway bar.  Four summers later and no problems or issues towing.  Of course, I've never towed with a WDH so I can't compare.  Good luck and have fun!
Rob
2012 HRE 177
2010 Toyota Tacoma
Posted By: frogpod
Date Posted: 04 Feb 2016 at 10:45pm
I have a 2003 Prerunner Taco and a 2010 171 Pod.  The Pod came with a cheap EZ friction sway bar which works well.  I noticed substantial sway one day but learned I needed to tighten up the sway bar a little more.  The truck came with a hitch receiver already which is not a Weight distribution type.   If I were starting over I would get a weight distribution hitch as the "porpoising".... if that is a word...is noticeable.  The friction bar is cheap and worth trying out if you already have a hitch. Will not help with the roller coaster feeling you get.
Leo and Tami
with Coltrane the Jack Russell Terrier
2003 Toyota Tacoma TRD
