Replacing shower faucet in bathroom
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7172
Printed Date: 16 Jul 2025 at 5:26pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Replacing shower faucet in bathroom
Posted By: podderfj
Subject: Replacing shower faucet in bathroom
Date Posted: 31 Oct 2015 at 10:22pm
I cannot stop my shower head from leaking in my 2010 172 when both my cold and hot water handles are turned completely off. I have removed the handles on both the cold and hot water from the faucet, removed the screw caps that retain the stud into the faucet, removed the rubber washers and springs that are inside the faucet in the water outlet holes. Went to Lowes tonight and got a complete repair system for the faucet, one repair kit for cold and one for hot. I am going to put all of this back together tomorrow with my new parts, turn my pump on and see if this will stop my shower head from leaking. For the head to leak, it HAS to be getting water past the sealing washers in the faucet when the hot and cold water are turned off. If this does not work, I guess my next step is to replace the entire faucet that is mounted onto the shower wall. In order to remove the faucet, I assume I have to access the back of the wall that the faucet is on. How do I access the back of the faucet in order to remove it from the wall. Do I have to remove the refrigerator in order to do this, and, if so, how do I remove the refrigerator. If any of my fellow podders out there have had to remove their faucet, I surely would appreciate your input and advice.
Thank you
Posted By: Podster
Date Posted: 01 Nov 2015 at 7:30am
Hmm, I'm not familiar with the layout of the 172, however...if I read your issue correctly I am wondering if just disconnecting the shower head hose attached to the faucet will stop it from dripping water out of the head? The only time we connect the shower hose is to prepare for taking a shower, otherwise it is disconnected to allow for drainage of the hose and to dry nicely as not to promote bacteria growth within the shower head/hose system.
------------- Cliff & Raelynn
Ranger 4.0/178
Posted By: techntrek
Date Posted: 02 Nov 2015 at 4:34pm
No need to disconnect it, it should have a weep valve on the bottom end which will drain the hose when it isn't under pressure.
