A couple of refrigerator questions
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7103
Printed Date: 20 Jun 2025 at 2:04pm
Topic: A couple of refrigerator questions
Posted By: Pete Brayton
Subject: A couple of refrigerator questions
Date Posted: 17 Oct 2015 at 11:52am
My factory installed frig seems kind of loose, meaning I can move it front to back in its cabinet.  When I open the outside access panels it looks like it is held in place by a flexible gasket.  Is this normal or has something come loose?
Also, in regards to the refigerator being level for proper operation...how level does it have to be and is it in the front-back or side-side directions or both that it needs to be level in? Thanks in advance for your replies!
Posted By: CharlieM
Date Posted: 17 Oct 2015 at 11:49pm
It's hard to get a fridge manufacturer to commit to numbers. They generally say if you're comfortable so is your fridge. With reference to the fridge itself it should be within 3 degrees side to side and within 6 degrees front to back. Since the fridge is mounted crosswise in the Pod those numbers are reversed when referenced to the trailer.
Posted By: Podster
Date Posted: 18 Oct 2015 at 7:12am
The fridge should not move. Here is a link to the proper installation instructions...
https://drive.google.com/drive/folders/0B2M4imcnGBJoV3YyNFRFMGVmWm8 - Meet Google Drive – One place for all your files
To check the level of your fridge in any given situation open the freezer door and place a bulls-eye level just inside. The level does not have to be perfect, just close enough to allow for the gases and liquids to run down and trickle from top to bottom using gravity.
Cliff & Raelynn
Ranger 4.0/178
Date Posted: 18 Oct 2015 at 5:30pm
More good information, thanks!
