How much antifreeze?
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7037
Printed Date: 20 Jun 2025 at 10:18am
Topic: How much antifreeze?
Posted By: GLBCamper
Subject: How much antifreeze?
Date Posted: 30 Sep 2015 at 10:44pm
Is one gallon enough to do the winterization as spelled out in the "manual" post here?
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Posted By: Keith-N-Dar
Date Posted: 01 Oct 2015 at 4:20am
I always over do it and use  one and a half.  I want to make sure I get everything safe.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: Tars Tarkas
Date Posted: 01 Oct 2015 at 8:12am
I usually use a little less than a gallon.
TT
FJ Cruiser
Posted By: SNO4ME
Date Posted: 01 Oct 2015 at 8:20am
Same here. A gallon would probably do just fine but it's cheap insurance.
Bruce & Donna in the Sno Pod
(and Brewer too)
2011 RP 177
Posted By: Outbound
Date Posted: 01 Oct 2015 at 8:28am
You'll also want to pour some down the sink(s) and into the shower pan drain in order to displace the water in the p-traps.  Better make it 2 gallons.
Date Posted: 01 Oct 2015 at 7:01pm
I've heard that you should clean up any pink antifreeze in the sink or shower pan after you pour some down the traps because it will leave a "sticky mess." But the instructions say to pour some in the toilet bowl and leave it for the winter. I know you don't want the flap seal to dry out, but it seems like leaving pink stuff in there might create another problem.
Old: 2014 177 HRE
2016 F150 4x4 Sport
Posted By: techntrek
Date Posted: 01 Oct 2015 at 10:18pm
Buy two, plan on using a little more than one, and a little more if you have a kitchen slideout like the 177, or a garage model.  Outbound is right that you should pour some in the traps, not sure if that is in the instructions. (edit: yes it is)
Never had a problem leaving it in the bowl or spots on the shower floor.  It always drips out of the shower head.
