weight limit for a replacement TV
URL: http://www.rpod-owners.com/forum_posts.asp?TID=7026
Printed Date: 20 Jun 2025 at 10:24am
Topic: weight limit for a replacement TV
Posted By: mesamie
Subject: weight limit for a replacement TV
Date Posted: 29 Sep 2015 at 9:29am
Has anyone replaced their TV, and if so is there a weight limit on the support beam the bracket is attached to ? I will be also be replacing the bracket, with a swivel one.
2016 R-179
Posted By: Podster
Date Posted: 29 Sep 2015 at 9:01pm
I don't know that you will find a published weight limit. I would stick pretty close to the weight of the original DTV. You could probably get by with something a little bigger, a pound or two, unless you want to re-engineer and mod the support to go way bigger. I'm not sure about the 179, but on my 178 the DTV is lagged into a 1" thick corner board on the corner of the bathroom framing. Not much there.
P.S. Also, you mention that a swivel is being added, suggesting there is none now? The swivel will increase the load significantly because of the extension of the weight out and away from the wall.
Cliff & Raelynn
Ranger 4.0/178
Posted By: Grandpa Hiker
Date Posted: 30 Sep 2015 at 6:01am
I replaced mine with a 21" in my 179. It seems so much bigger than the one that came in the Pod. I also replaced the bracket with a swivel type.
Rob & Becky
2015 R-179 Pod aka Piddle Pod
