TELEVISION WALL PLATE
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6980
Printed Date: 20 Jun 2025 at 3:31am
Topic: TELEVISION WALL PLATE
Posted By: funks
Subject: TELEVISION WALL PLATE
Date Posted: 18 Sep 2015 at 12:52pm
I have a 179 and I can't get any t.v reception. Living in the mountains away from any tv tower I figured that's the norm.
Here is my problem. We stayed at a KOA not long ago and they had electrical power and cable. When I hooked up I still didn't get any tv reception. I notice on the television wall plate that there is a button and a light on it. The light never lights up with the button out or in. I looked behind the plate and behind the radio/dvd player and all wire seem to be hooked up.
Wink    Has anyone else had this problem, and can you help?     John
Posted By: beachmaster
Date Posted: 18 Sep 2015 at 7:10pm
not sure what to tell you about the button other than it is, i think, the antena booost. make sure you go to mode on tv, change to air or cable then do a channel search otherwise nothing will work
Posted By: Wevitt
Date Posted: 18 Sep 2015 at 7:29pm
The button is a booster for when you do not have cable TV hooked up. I'm not sure if there is a fuse for it but mine lights up when pressed.
2016 Chevy Silverado 4X4
2016 RP179
Posted By: techntrek
Date Posted: 19 Sep 2015 at 8:41pm
If the light isn't coming on you have a power problem on that circuit - and it explains why you aren't getting any stations since it needs to be on unless you are connected to cable TV.  Have you checked the fuses on the converter?
