Leveling Jack help - Question
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6929
Printed Date: 13 Jul 2025 at 2:20pm
Topic: Leveling Jack help - Question
Posted By: cccrys
Subject: Leveling Jack help - Question
Date Posted: 07 Sep 2015 at 4:21pm
I have a question about the leveling jack.  Is the shaft of the tongue jack supposed to crank up so that it is flush with the bottom of the tube?  I really need about 2" clearance there for my driveway and it seems to hang down about 3 inches even when fully retracted.  That is the only problem I'm having with my inclined driveway & scraping.  We've tried the 2x10 boards and it just takes too much time and too confusing to use them while navigating an incline while at the same time turning in and out of the driveway. If I lift the hitch to the TV, the back end of the pod would scrape so I can't do that..... I need to get it resolved or DH says the Pod is going to storage.  Is there a replacement tongue jack that would work? I don't mind spending a bit of money - it would be cheaper than paying for storage.
What if I had it cut it down some and just brought extra blocks for leveling when needed???  Is that totally stupid to consider? Any help from all your RVing experience would be appreciated!!!
Crystal
Posted By: Leo B
Date Posted: 07 Sep 2015 at 5:03pm
Have you considered getting a different receiver with more of a drop or rise so that you get a little more clearance on the leveling jack. The receivers can go from straight, to 2" rise,3!/2" rise 4 " rise ?
Just a thought. If that doesn't work, another option is cutting a bit off with a saws-all and use a bigger block when disconnection
Posted By: scentralmt
Date Posted: 07 Sep 2015 at 5:08pm
I  got a swivel one.  Look at something like this.
https://www.etrailer.com/Trailer-Jack/Fulton/FTJ12000101.html - https://www.etrailer.com/Trailer-Jack/Fulton/FTJ12000101.html
Lots of choices, I have a dirt/gravel alley then concrete, so I got one that has 2 wheels instead of one so I can move it part way out into the alley.
Curtis
Curtis
2014 177
2001 F150
Posted By: cccrys
Date Posted: 07 Sep 2015 at 5:52pm
Wow, Curtis, that is a great piece!  What model pod do you have?  I see that the lift weight is 1200lbs.  Is that strong enough for a 179?  I don't really know much about what the manufacturer current set up will lift.  That would sure solve our issue.
Posted By: cccrys
Date Posted: 07 Sep 2015 at 5:53pm
Leo, can you show me what you mean?  Could you send me a link or picture about the receiver?
Posted By: techntrek
Date Posted: 07 Sep 2015 at 6:04pm
Swing-up jack worked for me.
Date Posted: 07 Sep 2015 at 11:06pm
I am guessing that the lift weight of 1200 lbs. is plenty.  You are only lifting the front hitch and the tongue weight is probably not more than 300 lbs.  I have at 177.
Curtis
Curtis
2014 177
2001 F150
Posted By: SchildPod
Date Posted: 08 Sep 2015 at 1:36am
our problem is with a steep/irregular driveway and the stabilizing jacks.    We are still pretty new, and have only backed into the driveway twice.   The first time went smoothly, although the stabelizin jacks were close to scraping.    The second Time, we bent one up pretty good, and wound up removing them to get it in place.
Any suggestions?
Date Posted: 08 Sep 2015 at 9:37am
You can buy mounts that let you remove them between uses. Or just crank them up, stick them under the frame and make them tight. Early pods didn't come with front stabilizers so I used a set of jack stands which worked really well.
Posted By: cccrys
Date Posted: 08 Sep 2015 at 6:54pm
Shcildpod, our rear stabilizers scrape a tad also but not enough to bend. I bought a pair of "sava jacks" to put on. I haven't put them on b/c it would require one to break the weld on the current bracket and I'm too chicken to try it myself. Or, at least I tried it and didn't even make a dent in the weld lol. They seem super easy to put on though.
Posted By: SiberD
Date Posted: 08 Sep 2015 at 6:57pm
You need a riser kit.
Posted By: cccrys
Date Posted: 08 Sep 2015 at 6:59pm
I ordered a swing jack but was wondering if I should also keep on the factory jack and have someone cut off the bottom of the tube so it will be flush. I guess I'm thinking I might need a backup at some point.   Would it hurt the resale value to remove it? I've never been very daring with modifying anything.
Date Posted: 08 Sep 2015 at 9:34pm
Use the swing-up jack.  3 bolts and the factory jack comes right off - but put them back in the holes to keep rust out of the threads.  When you are ready to resell give the buyer the option of either one, and if they want the original you can throw it back on in 15 minutes.
