LP detector power
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6417
Printed Date: 18 Jun 2025 at 1:45pm
Topic: LP detector power
Posted By: Pmorris1
Subject: LP detector power
Date Posted: 14 Jun 2015 at 1:37pm
I am getting the beeping from my LP detector because I have my battery disconnected when we are not using our Rpod. Is this going to hurt anything?
Posted By: techntrek
Date Posted: 14 Jun 2015 at 8:50pm
Yes.  The LP detector and the fridge electronics will drain the battery to the point that it is damaged in about 2 weeks.  Very soon after it will be dead for good.
You must disconnect the battery from the pod between trips unless you keep the pod plugged in, or you use a battery tender.  Reconnect every 30 days and plug in the pod overnight.  Then disconnect the battery again.
Posted By: CFWARREN
Date Posted: 14 Jun 2015 at 10:39pm
Unless I misunderstood the question, the question was, will having the battery disconnected harm anything, correct....? Very good question to ask, as I am in the same situation.
2016 179 - Hood River Edition
2008 Nissan Xterra
Posted By: Pmorris1
Date Posted: 14 Jun 2015 at 10:49pm
I don't think anything could be harmed, because with the battery disconnected, there is no power going to any electronics in the Rpod. I was just curious why my LP detector was beeping when the gas is off at the LP tank valve, and the battery is not hooked up. Doesn't make sense. As soon as I opened the door the beeping stopped.
Posted By: Podster
Date Posted: 15 Jun 2015 at 7:03am
If you have beeping with the battery disconnected, it's not the LP detector.
If you mean that you are disconnected and it beeps when you reconnect, it's probably because your battery it very low.
Cliff & Raelynn
Ranger 4.0/178
Posted By: furpod
Date Posted: 15 Jun 2015 at 9:29am
This. If the battery is disconnected the LP detector has no power. It can't beep or anything else. The things that CAN beep when the power is disconnected are the smoke detector and the carbon monoxide detector. They both have a 9v battery in them. try pulling/replacing those. In the small confines of the Pod.. it's often hard to tell just where a beep may be coming from..
