Anyone add an exterior propane access?
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6387
Printed Date: 18 Jun 2025 at 5:49am
Topic: Anyone add an exterior propane access?
Posted By: movemaine
Subject: Anyone add an exterior propane access?
Date Posted: 08 Jun 2015 at 7:54pm
My wife & I don't think we'll use the stovetop in the camper (smell, cleanup, etc.); we're more likely to use an external grill. I was thinking of purchasing a small portable gas grill that I could use outside and stow away when not in use.
Has anyone added an external propane line to a location not on the tongue?
Posted By: Camper Bob
Date Posted: 09 Jun 2015 at 10:17am
Yes we have. We put ours underneath the tongue as it was just a short run to the tanks. I had a 10' hose with a quick-connect on the tank side. Works great. I don't think it would be a problem to run a hose from the tanks under the belly to any other location that you would like. With the 10' length of hose, we can position the cook stove far enough from the Pod that we don't have to concern ourselves with grease from cooking sticking to the sides of the Pod. Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Posted By: furpod
Date Posted: 09 Jun 2015 at 11:33am
Remember you need a low pressure stove if tying into the pods supply lines AFTER the regulator. and a high pressure stove if you are tying in before the regulator.
Date Posted: 09 Jun 2015 at 11:49am
Always good advice from Furpod.  Actually we have a Weber portable BBQ with its own pressure regulator.  Took high pressure line to Weber and used its regulator.  This is what we use.  http://www.amazon.com/Weber-121020-Go-Anywhere-Charcoal-Grill/dp/B00004RALJ/ref=sr_1_15?ie=UTF8&qid=1433865245&sr=8-15&keywords=webber+grills
All good.  Safe Travels.
2016 Lance 1685
