Air Conditioning
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6376
Printed Date: 18 Jun 2025 at 5:45am
Topic: Air Conditioning
Posted By: goombah
Subject: Air Conditioning
Date Posted: 06 Jun 2015 at 5:20pm
Next newbie question!
Is there a reason why Rpods come with the 13.5k air units instead of a smaller 9k one?  I would think the latter would be more than sufficient to cool down such a small space.  I've seen much more spacious trailers with the 13.5k units.  Am I wrong to think this?  And a 9k unit would be way more genset friendly.  You could easily get away with a single Honda 2000 instead of duals or a heavier Yamaha 2400.  I have heard the 13.5k units are more economical to produce due to economies of scale.  Odd, but if that's true so be it.
What am I missing?
Posted By: CFWARREN
Date Posted: 06 Jun 2015 at 11:08pm
I have no idea, but my guess would be that Forrest River buys these units in mass quantities, and uses them across many platforms, not just the Rpods.
Makes sense, cost wise.
Same answer could apply to why they install the microwave oven, or TV mounting bracket, or any of dozens other items.  They buy them in bulk, to lower their cost.
2016 179 - Hood River Edition
2008 Nissan Xterra
Posted By: 68LC
Date Posted: 07 Jun 2015 at 12:27am
I'm not too worried as to why, since us desert dwellers (sometimes 120 in the shade, and there ain't no shade) believe that when it comes to air conditioning, some is good, more is better, and too much is just enough.  13.5 is fine.
You give peace a chance. I'll stay back here and cover you, in case things don't work out.
V/r;
68LC
2014 181g, now a 2017 180
Posted By: goombah
Date Posted: 07 Jun 2015 at 4:08pm
What genset are you using?  And how hard does it work to cool down/keep cool your trailer?  That's what I'd really like to know because if one can get away with a smaller generator then swapping out makes sense.
Posted By: Leo B
Date Posted: 07 Jun 2015 at 6:34pm
I am with 68LC the more the merrier!!
Posted By: Keith-N-Dar
Date Posted: 07 Jun 2015 at 7:21pm
To eeach their own.  We rarely use the air so it is no big deal for us.  For those that do use it a lot they have the option to change out their ac.  If gensets are  the issue it may be cheaper to change ac units than to buy two Hondas.  In 2011 when we bought our pod the local Honda dealer wanted over $2,000 for enough generator to handle all pod duties.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: techntrek
Date Posted: 08 Jun 2015 at 3:35pm
I http://www.rpod-owners.com/forum_posts.asp?TID=1433 - explored many options for downsizing the A/C .  I agree it is too big for the space, with the biggest problem that they cycle off too fast to remove much humidity.  You actually get more cooling action from the removal of the humidity than lowering the temperature, and you need a long cycle to do it.  The pods have more then enough insulation to handle 120 degree heat even with a smaller A/C - I camped down to 10 F and kept the inside temp at 70 with a small cube heater.
