Battery acid or distilled water?
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6355
Printed Date: 18 Jun 2025 at 5:49am
Topic: Battery acid or distilled water?
Posted By: David D
Subject: Battery acid or distilled water?
Date Posted: 02 Jun 2015 at 8:41pm
Hi Everyone,
Wondering which I should use to top my battery's cells; battery acid or distilled water?  Any comments?  I've pasted a link below to the battery acid...
http://www.oreillyauto.com/site/c/detail/SSBF/32096.oap?ck=Search_32096_-1_-1&keyword=32096
Thanks!
David
2015 R-Pod 179
Posted By: CharlieM
Date Posted: 02 Jun 2015 at 8:45pm
Only add pure distilled water.
Posted By: ToolmanJohn
Date Posted: 02 Jun 2015 at 8:48pm
Distilled water. If the batteries have evaporated some of the water, you just need to add it back in, distilled is preferable (no minerals). After you have added (not overfilled) enough, charge the battery fully, then after a few hours off the charger,  check the electrolyte strength with a tester. You should be good to go.
 If a battery is VERY low on water, it may cause sulfation of the lead plates. After filling with water, you may need to use a special charger that can desulfate the battery if necessary.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Posted By: techntrek
Date Posted: 02 Jun 2015 at 9:55pm
You can buy distilled water cheaply at Wal-Mart, I think it is 99 cents per gallon.  I used to maintain a large battery bank and went through gallons of it every 6 months.
Posted By: David D
Date Posted: 02 Jun 2015 at 11:31pm
Thanks to everyone for their replies!  I'm very grateful to have a trusted source for my rPod questions.
...heading out the door to return the battery acid.
Thanks again, everyone!!!
2015 R-Pod 179
Date Posted: 03 Jun 2015 at 7:56am
If you haven't read up on it yet, make sure you are keeping your battery charged properly.  Lots of threads here on the topic, including one in the "pod manual", see the link in my signature.
Posted By: David D
Date Posted: 04 Jun 2015 at 11:27pm
Doug,
Thanks very much!  I checked the link at the manual page; very helpful!  Thx for setting up this terrific resource for r-pod owners.
2015 R-Pod 179
