Lippert Axle EZ Lube Question
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6295
Printed Date: 18 Jun 2025 at 12:44am
Topic: Lippert Axle EZ Lube Question
Posted By: johnmaci
Subject: Lippert Axle EZ Lube Question
Date Posted: 24 May 2015 at 8:34am
Sorry about asking this if it has been answered before Embarrassed
I currently have mine parked in a outside storage facility, and the ground is gravel.
I have seen lots of videos on greasing the axle bearing and they all mention spinning the wheel while injecting the grease.
Is this really necessary or can I get away with just pumping until I see my royal purple start oozing then let nature take its course when I start towing?
Thanks,
JD
Posted By: furpod
Date Posted: 24 May 2015 at 2:00pm
Yes, very necessary. Otherwise it will at best tunnel, at worst, blow the gasket out the back.
Posted By: johnmaci
Date Posted: 24 May 2015 at 3:25pm
Thank you, I have to find some boards or blocks to put on the soft ground.........
