A/C Removal & Fan Install
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6215
Printed Date: 18 Jun 2025 at 1:12am
Topic: A/C Removal & Fan Install
Posted By: Nick
Subject: A/C Removal & Fan Install
Date Posted: 12 May 2015 at 2:26pm
Hi Everyone,
Ok so I think I bit off a bit more than I can chew on this one.
So I removed the Dometic A/C unit on my R-pod 178 (no issues on that)
I have put in a 2250 Fantastic Fan in its place
My issue is the wiring.
When I wire it all up I get a E1 error message on the thermostat and I have an extra blue wire that used to attach to the A/C unit.
I have no control over the heater output it just runs and runs once the heater gets power.
Is it possible that I need to replace the thermostat to just a 2 wire heater thermostat?
Any help would be greatly appreciated
Thanks
Posted By: Nick
Date Posted: 12 May 2015 at 3:44pm
ok, it looks like the blue wire is a common wire. And since the new fantastic fan doesn't come with a terminal to hook a common wire into, my thermostat and my heater won't work.
Any ideas?
Posted By: furpod
Date Posted: 12 May 2015 at 6:00pm
The fantastic fan is a stand alone unit, I don't think you can run it off a wall thermostat.. I have one that runs off it's own wireless thermostat/remote control.
Posted By: marwayne
Date Posted: 12 May 2015 at 6:42pm
Nick, bin there done that, I guess your furnace fan is running but the gas won't come on, you need to install a new plain and simple 2 wire thermostat.
Posted By: Nick
Date Posted: 12 May 2015 at 7:12pm
Yes Marwayne
You are exactly right!
I Just tried a $12 thermostat and it seems to work just fine. Now I just gotta rewire the new TS.
Thanks for the replies everyone
Posted By: Dreded
Date Posted: 30 May 2015 at 12:14pm
i would love to know more about this.. was the fan a direct replacement how hard was it to install?
2015.5 RPOD 171
Posted By: Nick
Date Posted: 01 Jun 2015 at 12:09am
I bought a 2250 Fantastic Fan to replace the A/C.
As for structure, everything fits as it should, A/C hole is the right size for the Fan to fit into.
Wiring was tricky as I'm not an electrician. Take your time, and label each wire (even if you don't know what the wire does) that way you know what wire goes where. You'll need to switch out the existing thermostat for a simple 2 wire one (see conversation above).
I also put a clear lid on the fan as well (no tint). There is a ton more light inside now.
All in all i never used the A/C so there was no use having it. I might as well put the space to better use.
Posted By: techntrek
Date Posted: 01 Jun 2015 at 11:10am
Now you can sell the A/C, although you may want to keep it and swap it back in when you are ready to sell the pod.
