Heat
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6212
Printed Date: 17 Jun 2025 at 6:25pm Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Heat
Posted By: Travelcottage
Subject: Heat
Date Posted: 12 May 2015 at 11:24am
I'm new to whole pod thing so forgive ignorance....when I turn furnance on the AC fan blows...is that how it's suppose to be?
And what does " heat strip" mean on thermostat?
Thanks
------------- Cheri
Posted By: CharlieM
Date Posted: 12 May 2015 at 11:30am
The AC fan thing is a common issue with Pods. On the thermostat set the fan to auto, not high or low. That should fix it. The heat strip is an option not normally, if ever, installed. I doubt you have it.
------------- Charlie
Date Posted: 12 May 2015 at 11:33am
Awesome...setting it to auto worked....my papllion is happy as he doesn't like the noise on the AC fan...
Is there a way to tell if heat strip was installed? The light on thermostat lights up?
------------- Cheri
Posted By: CharlieM
Date Posted: 12 May 2015 at 11:39am
Originally posted by Travelcottage
Is there a way to tell if heat strip was installed? The light on thermostat lights up? |
Can't say for sure since I don't have one, but it can't hurt to try. Set the thermo all the way up, set it to heat strip, and see if heat comes out of the AC vent.
Date Posted: 12 May 2015 at 11:51am
So gave it a try and I get heat.....
Thanks for your help.
------------- Cheri
Posted By: CharlieM
Date Posted: 12 May 2015 at 11:57am
You're quite welcome.
NOTE to TechnTrek: Verrrrry interesting!
Posted By: furpod
Date Posted: 12 May 2015 at 12:37pm
We have seen a few with it installed for whatever reason..
Posted By: techntrek
Date Posted: 15 May 2015 at 3:27pm
Interesting, yes. Mine had it but there was no way to control it from the thermostat. It also caused a lot of noise when the A/C ran so I removed it.
