Refer questions
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6034
Printed Date: 16 Jun 2025 at 10:22pm
Topic: Refer questions
Posted By: kylekai
Subject: Refer questions
Date Posted: 05 Apr 2015 at 3:20pm
I have a 2015 179, and have a couple of refrigerator questions:
1. Anyone know where can I purchase refrigerator replacement parts?  I may have overloaded the plastic door shelf - the shelf that can hold milk and is adjustable.  It's now cracked a bit.
2. I noticed the back of the vegetable bin is shaped somewhat like a U, whereas the refer is square.  Seems like the two back corners could have been square also, allowing more room for food.  Is it intentionally U shaped for ventilation or some other reason?
Thanks!
Posted By: Outbound
Date Posted: 05 Apr 2015 at 5:19pm
Dometic refrigerator parts are pretty much only available through an RV dealership / parts store.  Dometic doesn't sell directly.  You'll likely have to order parts like shelves, and its not going to be cheap.  You may want to take a second look and determine if you can adequately repair with plastic weld or epoxy.
And, yes, the crisper tray is intentionally designed to allow airflow.  The cold air flows downward from the "coldsink" (opposite of a heatsink) at the top rear of the fridge, so you should take some care about how tightly you pack the fridge.  Mind you, I usually remove the crisper tray so I can pack in more food and have never had a problem.  Just make sure that there are some vertical spaces at the rear of the fridge so the cold air can work its way down.
Posted By: Leo B
Date Posted: 05 Apr 2015 at 5:38pm
I agree with Outbound, we do the same thing removing the crisper tray for the extra space.
Posted By: kylekai
Date Posted: 05 Apr 2015 at 11:50pm
Great, thanks!
