Valve positioning for filling water heater
URL: http://www.rpod-owners.com/forum_posts.asp?TID=6009
Printed Date: 18 Jun 2025 at 5:16am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Valve positioning for filling water heater
Posted By: calmdowneight
Subject: Valve positioning for filling water heater
Date Posted: 31 Mar 2015 at 10:58pm
Which valve fills the water heater and what orientation should valves be in for operation? Which orientation is bypass for winterization? Getting ready to fill the fresh water tank and camp in the yard on Thursday so that we can test all systems well before our first trip out. I forgot to ask the dealer how to fill the water heater and don't want to ruin the water heater right out of the gate. We have the 2014 178 so I assume everything is under the bed. Thanks and if you have links to pictures that would be helpful.
Posted By: marwayne
Date Posted: 31 Mar 2015 at 11:39pm
This is the position of the 3 valves for summer use, revers the 3 valves for winterization.
------------- If you want something done right, do it yourself.
Date Posted: 01 Apr 2015 at 7:27am
Sounds easy enough. Thanks for the help!
Posted By: kellyandkelly
Date Posted: 07 Jun 2015 at 12:57am
Posted By: Tars Tarkas
Date Posted: 07 Jun 2015 at 1:55am
Originally posted by kellyandkelly
Is it under the bed? |
It varies by model. Marwayne added hinges to his WH cover. You probably have to remove 4 screws in the the corners of the panels. (I replaced my screws with velcro.) It's easy to tell where the water heater is by looking at the outside.
You should explore. I think every ankle-level panel that is screwed on has something behind it that you need to deal with at least twice a year.
TT
------------- 2010 176
FJ Cruiser
Posted By: Leo B
Date Posted: 07 Jun 2015 at 7:38am
Agreed, you do need to explore the tucked away stuff.......plus it is kind of fun!
------------- Leo & Melissa Bachand
