Tow vehicles
URL: http://www.rpod-owners.com/forum_posts.asp?TID=5907
Printed Date: 08 Jun 2025 at 4:31am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Tow vehicles
Posted By: Larry158
Subject: Tow vehicles
Date Posted: 03 Mar 2015 at 9:53am
Tow vehicle? Coming up on spring & my tv is a Denali 6.2 liter engine. Needless to say I am not setting any MPG records towing my new 178. Getting 10.5. Looking to acquire a replacement second vehicle. What are members getting MPG wise & what vehicles are being used. Thanks for your response in advance Larry158
Posted By: furpod
Date Posted: 03 Mar 2015 at 10:39am
10-12 mpg is pretty much the range most see, regardless of vehicle.
Posted By: Podster
Date Posted: 03 Mar 2015 at 4:02pm
True, I'm pulling w/ a 1/2 ton Ford Ranged V6 4.0 and I get 12.
------------- Cliff & Raelynn
Ranger 4.0/178
Posted By: Leo B
Date Posted: 03 Mar 2015 at 4:06pm
I tow with a 2013 Dodge Grand Caravan with the 3.6 v -6 that puts out 290 horse power, depending on the wind, we average anywhere from 13.5 to 16 miles per gallon, this is carrying maybe 5 gallons of water and our clothes and kitchen stuff. This is usually travelling out of the mountains of Vermont down to the flat lands of Massachusetts and below. We usually are driving around 55-60 mph. I am really happy with its performance
------------- Leo & Melissa Bachand
Posted By: techntrek
Date Posted: 03 Mar 2015 at 4:46pm
Pulling our pod with our Suburban I would get 10-11 on local trips, but on two 4 week trips I averaged 9.5-9.7. That was with A/C in 100+ temps and many hard hauls up mountainsides.
Posted By: Keith-N-Dar
Date Posted: 03 Mar 2015 at 8:36pm
My pre Eco-Boost F150 super crew will get 15 MPG on the flat pulling our 177 IF I stay under 60. At 70 it drops to under 10. I remind myself that I am on vacation and keep it slow. The Rockies also help keep mileage down.
------------- Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: obu2
Date Posted: 03 Mar 2015 at 10:12pm
We towed our R-171 with a 2012 Chrysler T&C, V6, 6 speed. Horrible. Went to 2 Chrysler service managers and they said no problem. Went to 2 r-pod dealers....no worries. Hooked it up and headed for the maritimes. Way underpowered. Constant downshifting with the slightest grade. MPG was 11.5 and with a small gas tank, we had to stop every 2 hours if we could find a fuel stop. Canada doesn't have one every couple of miles. So, we traded it for a Dodge Durango V8 HEMI MDS VVT. Huge difference.
Date Posted: 04 Mar 2015 at 10:27am
Welcome. My experience was similar to yours with the Sienna we used before our Suburban. Downshifting with the slightest incline (worse with a 4-speed) and gas stops every 3 hours. Fine for local trips, but after 2 long trips (MD to ME and MD to FL) I knew we needed more before we hit the Rockies.
Posted By: J&Jcf
Date Posted: 04 Mar 2015 at 6:15pm
Tow with 2004 f150 supercab with 6.5 bed & 5.4 liter v8 & 3.73 rear end tow package. Pulled 27ft. Travel trailer (Award aerodynamic & low profile at 5000 lbs.) And got 10 to 13 mpg driving listed speed limit. Now towing the 171 pod with same TV and get same mpg. Rpod has higher profile than previous trailer. Plus- TV only gets 18 mpg by its self. The big difference between TV is when you get to the destination and unhook. The time spent sightseeing with TV. I personally like towing with a larger TV ,but my current TV is overkill. If and when l purchase the next TV it will be a p-up with a smaller v8 or v6. It would have tow package because you get heavy duty radiator, alternator & transmission cooler as well as other features. The one thing l would look to down grade is the rear end (differential). I would get a 2.73 or 3.55 . lighter weight truck,smaller more efficient engine & higher rear end would increase mpg at least during nontowing times.
------------- J. - 2011 rpod 171
Posted By: txbonds
Date Posted: 04 Mar 2015 at 8:06pm
My lifted 2015 4Runner with oversized tires and 4.0 V-6 will average 35 MPG pulling our 171.
Just kidding. I'm averaging about the same 10 to 15 range depending on terrain and speed. :)
Date Posted: 04 Mar 2015 at 8:22pm
Originally posted by J&Jcf
...The one thing l would look to down grade is the rear end (differential). I would get a 2.73 or 3.55 . lighter weight truck,smaller more efficient engine & higher rear end would increase mpg at least during nontowing times. |
One advantage of the newer 6-speed, and definitely with the 8-speed trannys, is less of a need for the low rear gear ratios, so I think you have the right idea. You really only need it low off the line, and 1st and 2nd on the 8-speeds are very low.
Posted By: ToolmanJohn
Date Posted: 05 Mar 2015 at 4:49pm
One advantage of the newer 6-speed, and definitely with the 8-speed trannys, is less of a need for the low rear gear ratios, so I think you have the right idea. You really only need it low off the line, and 1st and 2nd on the 8-speeds are very low. |
True about the 8 speed transmissions. First two ratios are VERY low. I get 15mpg towing the Pod at 65mph with cruise set. If I can tolerate driving at 55mph, then it climbs to 17mpg towing. I have the TDI (diesel) version of the Touareg.
------------- 2017 ATC 7X20 Custom Toy Hauler
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Posted By: Larry158
Date Posted: 06 Mar 2015 at 10:59am
All, To all who responded to my query my hearfelt thanks. I believe I will stick with my present TV until something better comes along based on your responses. Tongue jn cheek I was ready to research the availability of a lifted Toyota 4 runner in my area until I scrolled down to the bottom of the message.
Thanks again Larry158
Posted By: dsmiths
Date Posted: 07 Mar 2015 at 7:58pm
two things all men Lie about is Gas Mileage, and their Sex Life.
------------- Dane and Donna Smith
2011 RP-172
lift kit
Posted By: Leo B
Date Posted: 07 Mar 2015 at 8:09pm
I have heard some tell fish stories also
Date Posted: 07 Mar 2015 at 8:53pm
Size always matters.
For fish stories, of course.
Posted By: Leo B
Date Posted: 07 Mar 2015 at 9:20pm
Posted By: thetower
Date Posted: 30 Mar 2015 at 8:15pm
Hello . We tow are 179 witt a dodge journey 2012 6 cyl and it is the same gas millage . Same speed . And it is verry safe and we enjoy the way down the road. We like verry mutch the match . We go to south carolina 3 time s a year . We are chasing the warm weather. Bon voyage les amis
------------- Born to be outside
Posted By: WIRpodder
Date Posted: 05 Apr 2015 at 9:28am
I have a 03 4Runner with the V6 and tow package also and looking to get a 171 this week. Have you pulled in high winds or in the mountains? Do you use a WDH?
Thanks!
Date Posted: 05 Apr 2015 at 1:09pm
Thanks!
I also had a 2003 4Runner V6 Limited 4 speed AISIN automatic transmission. They all came standard with the tow receiver (rear cross member mounted).. There is an optional frame mounted receiver which allows slightly higher tow capacity (tow weight and tongue weight).
Stock 4Runner V6 has capacity 500/5000 (Tongue/Tow). It will tow an RPod "OK" . It will NOT tow well at 65-70 mph unless it's flatland, and you will never be able to use the 4th gear. You must leave it in 3rd, or the transmission will hunt like crazy towing 3000 pounds or more.
Hills at any highway speed are taking at a leisurely pace. Accept that towing several thousand pounds will be at 50-55 mph on the highway heading uphill.
I replaced my 10 year old 4Runner in 2013 with a diesel SUV because of my towing experiences, distance towing, and generally it was time for a more efficient vehicle anyway. The 4Runner was still in great condition, and was practically oil changes and scheduled maintenance only. Very few mechanical issues in 10 years. Sold it to a friend, who doesn't tow, he still uses it as his daily driver.
2013 VW Touareg TDI
Posted By: fwunder
Date Posted: 06 Apr 2015 at 3:25pm
Just to throw in one more data point. We tow our 2014 178 with an 08 4Runner Limited. Very comfortably. We just returned from a ten day trip to Florida and back (New Jersey) and this past summer did a 8,000 mile journey to The Pacific coast and back. The Pod and 4Runner have done both east and west coasts and points between. Have had no problems at all, including an "interesting" westward drive across Wyoming with 55 mph headwinds. We normally cruise about 60-65 and get 12-15 mpg depending on wind and terrain.
-fred
------------- 2014 RPod 178 => https://goo.gl/CV446f - MyMods and Buying Habits
Posted By: Newsguy12
Date Posted: 06 Apr 2015 at 6:48pm
My original TV with our 2015 179 was a 2014 Jeep Cherokee Trailhawk with the 3.2 Pentstar V6. We averaged about 16 MPG towing throughout the summer. But I can't recommend the Cherokee even though the R179 loaded is well under the new Jeep's tow rating of 4500 lbs. I was extremely happy with it until the tranny blew last month driving solo! I've since discovered that a lot of these trannys have gone south in this new model Jeep. So, after the warranty replaced the tranny, traded it in for a 2014 Ram 1500, 5.7 Hemi. I pulled the 179 on a 130 mile round trip from Cincinnati to Lexington to see what the MPG would be. 12.0.
------------- Ram 1500
5.7L V-8 Hemi
2015 R-Pod 179
Posted By: ShellDave
Date Posted: 06 Apr 2015 at 8:01pm
I tow my 178 with a Toyota Tacoma Pre Runner V6 and avg 10/12 mpg. I don't have many issues with the trailer moving around behind me.
------------- Dave
Date Posted: 07 Apr 2015 at 10:27pm
Thanks for the info, much appreciated! Local dealer is setting me up with a brake controller and I am going to test drive the 171 this week, I want to make sure before I purchase.
Date Posted: 11 Apr 2015 at 7:36pm
Test drive went pretty well, except for the lack of overdrive off button. Transmission jumped between overdrive and 4th (4 speed 03' 4Runner V6) and was disappointing that I could not just stay in 4th.
There was a slight rear end sway, so I plan to get a WDH. The dealer has two options, one the Equalizer (~$600) and the other a newer Husky model (~$400). Other postings have shown the Equalizer to be a good choice, has anyone had experience with the Husky version?
Date Posted: 11 Apr 2015 at 9:52pm
I was right about the 4 speed transmission. Hunting 3rd, 4th... It is not all the the transmissions fault though, it's the torque (286 ft/lb if I remember correctly). Leave it in 3rd gear so it doesn't hunt, and you have a decent 3 speed.
My bicycling pal has a 2004 SR5 4Runner, 5 speed, same 4.0 V6, and he tows a T@B trailer. Not the same as a POD in weight , BUT he cannot tow in 5th either at 65mph, and his T@B weighs UNDER 2000 pounds. So the 4Runner V6 just doesn't have tons of torque, that's all. No speed records to break when towing anyway.
When I towed with the 4Runner through Mass and Vermont, it was 60-65 in 3rd all the way (240 miles each way). If I remember, about 3100 rpm at those speeds on the flats, 10-13 MPG. Transmission temps were good, but I installed a B&M cooler inline with the transmission radiator anyway.
2013 VW Touareg TDI
Posted By: Sleepless
Date Posted: 12 Apr 2015 at 11:02am
I have used the same Husky WDH on my last 3 trailers. Absolutely no problems and the price is right. I am also still using the same sway control, an inexpensive friction model, and, again, the price is right.
------------- 2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Posted By: Jpntime
Date Posted: 12 Apr 2015 at 10:04pm
My 171 sways a little bit when empty put a little bit a water in it and it goes away
------------- Love to camp
2014 171
Posted By: Hecklertravel
Date Posted: 04 Jul 2015 at 2:36pm
We bought a new tow vehicle last year at the end of summer. And this will be our first year out with it. We will be pulling our 182g with a 2014 ram 2500 cummins. I am waiting to see what we get for fuel economy. Oh I can't wait.
Date Posted: 04 Jul 2015 at 11:03pm
Welcome. You should get a decent mpg with that rig.
Posted By: Leo B
Date Posted: 05 Jul 2015 at 8:59am
Can you post it when you find out?
Posted By: JohnBG
Date Posted: 05 Jul 2015 at 4:53pm
Just did my first shakedown trip to a local campsite with my 2010 RP-171, the Honda Ridgeline towed the camper with no problems. No WDH. Averaged about 12 mpg.
------------- 2010 R-Pod RP-171
2010 Honda Ridgeline TV
Posted By: sailor323
Date Posted: 05 Jul 2015 at 7:24pm
We are partway into our maiden trip. Have gone about 600 miles from S Central KY to Upstate New York. The Toyota Tacoma has averaged 15MPG
Posted By: Leo B
Date Posted: 05 Jul 2015 at 7:26pm
That decent mpg!!
