TV and DVD Operation
URL: http://www.rpod-owners.com/forum_posts.asp?TID=5661
Printed Date: 23 Jun 2025 at 7:04am
Topic: TV and DVD Operation
Posted By: greg.todd
Subject: TV and DVD Operation
Date Posted: 02 Jan 2015 at 12:32pm
Okay folks. I am embarrassed to say I couldn't figure out how to watch a DVD last night. Which input should the tv be set on? It's any other cable required other than the Motorola video cable from the well to the video input on the tv?
Would you believe I'm in charge of an engineering group and I couldn't figure this out.
Date Posted: 02 Jan 2015 at 4:36pm
RCA cable/connector, not Motorola. Had Motorola on the brain.
Posted By: Podster
Date Posted: 02 Jan 2015 at 7:31pm
My POD is in storage so I can't review the set up, however, it really should be as easy as loading a DVD. Once you have confirmed the Jensen is spinning the Disc, riffle though the inputs and one of them should show. Could it be the disc itself? Are you loading it correctly? Some DVDs will spin but not play anything if loaded up side down.
I know that's not much help, but if the RCA jacks are connected properly, I can't think of anything else (simple) that may cause it to fail. I guess the next step is to start the trouble shooting by removing the DVD source by attaching a different DVD player so you can rule out the TV. Good luck! Come back and let us know how things work out, that's how we learn here.
Cliff & Raelynn
Ranger 4.0/178
Posted By: furpod
Date Posted: 03 Jan 2015 at 9:51am
What model Pod, they do not all have the same system.
Date Posted: 03 Jan 2015 at 12:32pm
I ended up just using my laptop and vga cable directly into the tv. I'll figure out out once we get home and let you know what I find.
2014 R-Pod 179
Thanks everybody.
