tight entry door
URL: http://www.rpod-owners.com/forum_posts.asp?TID=5526
Printed Date: 27 Jul 2025 at 12:17pm
Topic: tight entry door
Posted By: rpodbend
Subject: tight entry door
Date Posted: 06 Nov 2014 at 1:57pm
Wow is this door tight and hard to open.  We just took delivery on the 178.  the door sticks so tight that my wife can hardly open it from the inside.  And me too, I have to really force it to open.  I will bet the answer is to take it back to the dealer but it's a pain.  After it is about an inch open the door swings quite stiffly but that is how I think it's designed.
I haven't seen any quick easy remedy as I think it's just hung up until forced open.
Any similar experiences?
Loren Ouch
Loren and Sally and Bear
Rpod 178 2015
Bend Oregon
Posted By: kymooses
Date Posted: 06 Nov 2014 at 3:37pm
The doors are the new type friction hinge style type, they are meant to be like that.  It seems though you are experiencing an abnormal case of what the design is supposed to do.
I've not seen anything from Lippert about adjusting these hinges.
From what I've been told they will become more fluid the more you use them, and lubricating them some does seem to help.
Good luck
Posted By: techntrek
Date Posted: 06 Nov 2014 at 7:45pm
Have you checked the door frame to see if it is rubbing somewhere?  That would explain why it gets easier after it is open an inch.
Posted By: Goose
Date Posted: 07 Nov 2014 at 11:53am
Welcome rpodbend, is it the outside door that drags or the screen door? Our screen door has always dragged a little and when the trailer is not set level it can be a little tougher to open. Goose
Posted By: rpodbend
Date Posted: 07 Nov 2014 at 12:03pm
I appreciate the feedback. Yup, I think it's the door frame. Screen door fine.
Loren
Rpod 178 2015
Bend Oregon
Date Posted: 07 Nov 2014 at 1:40pm
If you can see where it is rubbing, take a hammer and a block of wood and try to bang the frame out in that spot.  Hit the wood with the hammer so you don't leave any marks.  It won't take much movement in the frame to get the door to clear.
Posted By: kymooses
Date Posted: 08 Nov 2014 at 9:15am
Loren
Screen door is not on the same friction hinges though.
Interested though to see what you end up finding out, keep us posted and hopefully it works better for you eventually.
Posted By: rpodbend
Date Posted: 08 Nov 2014 at 10:06am
Rpod 178 2015
Bend Oregon
Posted By: rpodbend
Date Posted: 08 Nov 2014 at 10:08am
Oh man!  All I did was take the latch on the door off and put it back on and whammo! all is good with the world and hey, my wife can actually get out of the R pod!   So it was just the adjustment on the latch.
Sorry to have put all you good people to work on something that was so simple to adjust.
Thanks to all
Loren and Sally and BearSmile
Rpod 178 2015
Bend Oregon
Posted By: kymooses
Date Posted: 08 Nov 2014 at 4:21pm
Oh, that's great.
Sorry I was misunderstanding you problem there.  Thought it was tight once opened and swinging.
So you adjusted the strike plate on the door frame or did you actually adjust the door lock latch part?
Either way, great job!!
