Battery maintainer
URL: http://www.rpod-owners.com/forum_posts.asp?TID=5253
Printed Date: 20 Aug 2025 at 2:44pm
Topic: Battery maintainer
Posted By: 2McPods
Subject: Battery maintainer
Date Posted: 03 Sep 2014 at 9:57am
Hello, any thoughts on battery tricklers/maintainers? Good,better,best brands? Thanks
Everything Happens 4 A Reason
Pat & Viki McCartney
2015 171 {2McPods}
2014 F150
Pittsburgh, Pa
Posted By: johnmaci
Date Posted: 03 Sep 2014 at 10:25am
I have three Deltran battery Tender Jr's, and they work great for my three marine batteries. Very inexpensive too.
If the battery state is low, it will stay red for a few days bringing up, then will turn and stay green in trickle.
Posted By: furpod
Date Posted: 03 Sep 2014 at 2:00pm
The pod has a pretty good built in system, if you can park/store within reach of an outlet.
Posted By: Sleepless
Date Posted: 03 Sep 2014 at 5:34pm
If you need to recondition a deep cycle battery, members of the 2 shrimping and fishing clubs I belong to here in east central Florida swear by the Battery Minder.  This is not a "battery tender" but a unit that will actually extend the life of an old or neglected 12 volt deep cycle battery.  I have been using mine for about 12 years and can normally keep these batteries for about 6 years.
http://www.amazon.com/BatteryMINDer-Charger-Maintainer-Desulfator-System/dp/B00D7HZ6FC
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Posted By: freezingalaskan
Date Posted: 03 Sep 2014 at 7:24pm
For winter I take the battery out of the pod and have it in my garage together with motorcycle/generator maintaining purposes. I use this Optima device and switch between the batteries periodically. More expensive than the Battery Tender, but "more fun to look at".
http://www.amazon.com/Optima-150-40008-Battery-Charger/dp/B00DHGPVKI/ref=sr_1_57?ie=UTF8&qid=1409786567&sr=8-57&keywords=battery+maintainer
freezingalaskan
Volvo XC90 '13
rPod 179 '16
Posted By: techntrek
Date Posted: 03 Sep 2014 at 8:05pm
Sounds like a situation where the batts should be topped off with a charger first, usually the battery tenders only output 1-2 amps.  On older batteries especially, that would barely keep up with the self-discharge rate, let alone put a charge on them.
Posted By: WillThrill
Date Posted: 10 Sep 2014 at 9:16pm
That's a great point. 'Trickle' chargers often don't have sufficient amperage to charge up batteries. On top of that, they output a constant voltage/amperage, no matter what. You NEVER want that. You want a charger/maintainer that is 'smart' and adjusts its output according to the state of your batteries.
Like others, I have had great success with my Battery Minder #1500. It takes the ambient temperature into account, which is a great plus. However, battery maintainers like this should only be used AFTER the batteries are fully charged or nearly so.
2014 Hood River 177
2005 GMC Envoy XL
