Jensen Entertainment - 2014 178
URL: http://www.rpod-owners.com/forum_posts.asp?TID=4744
Printed Date: 20 Aug 2025 at 10:02am
Topic: Jensen Entertainment - 2014 178
Posted By: ANGCHIEF
Subject: Jensen Entertainment - 2014 178
Date Posted: 19 May 2014 at 10:45pm
Just got home from the maiden voyage of our 2014 RPod 178 and it was a great trip (Central Michigan). Everything worked as advertised except we could not get a DVD to play on the entertainment system. Jensen 1914. Anyone out there have any answers? The system came with red and yellow cables, but couldn't find any hookups on the DVD player as it is mounted in the wall. It was close to 30 degrees at night but the furnace helped and we supplemented with a small electric heater. Looking forward to hearing from all you great podders!
Jan and Dean
2014 178
Posted By: Hairy Podders
Date Posted: 20 May 2014 at 7:01am
After you put the DVD in the "radio", you have to change the source on the TV. We have watched a couple of movies in our '14 178. Since watching the second one, the radio quit coming on randomly by itself. Probably operator error....
Darryl, Julie & Lindsey
2014 RP178
Posted By: ANGCHIEF
Date Posted: 20 May 2014 at 7:52am
Change the Source to what - a few of the choices were AV and component. I believe.  We tried both.  You didn't do anything with the extra cables, correct?
Sure glad yours worked!!!
Jan and Dean
2014 178
Posted By: wingnut2312
Date Posted: 20 May 2014 at 8:03am
Are the cables connected to the tv? There shouldn't be extra av wires hangin around. If there are, then somethings not hooked up. The dvdplayer is hooked up internally (behind the wall). The input selection on your tv corresponds to which plug in you're using. Check the back. Whichever input you attach the wiring to is the same as the tv input.
You will be using video 1 or 2. There isn't a component hookup on the wall bracket that I know of.
2014 rpod 182G
Ford Expedition
Posted By: ANGCHIEF
Date Posted: 20 May 2014 at 8:37am
There is a cable from a fitting on the wall to the TV and that's all.
We have a small TV/DVD player that we bought for our truck camper and we had to change the source on the TV, also and there wasn't any problem.  Just not sure what the source would be.
I pulled up the TV manual online.  It says to turn on the TV, select "Component"and then turn on the DVD player, insert the DVD and press Play.  Will take out another DVD and give that a try!
Thanks - knew I'd get an answer from one of you fellow Podders!!
Jan and Dean
2014 178
Date Posted: 20 May 2014 at 9:00am
On the wall bracket is there a red, green and blue plug? That's component. The red, white and yellow are Video 1 or 2. The tv will have a component hookup, but the wall will not. You will have to connect the re, white and yellow from the wall to your tv.
You will also have to switch the radio/dvd player to dvd. Then switch the tv. Just make sure the wires are plugged into the right colors. Either way, you need to connect the red, white and yellow to the wall bracket. The single wire is the the black cable wire.
2014 rpod 182G
Ford Expedition
Posted By: Budward
Date Posted: 20 May 2014 at 4:07pm
The source will be the one that you can see video onLOL  Sorry- had to say itEmbarrassed
As a side note I found I couldn't hear the tv over the air conditioner blast.  FR elected not to run one more pair of audio cables to feed audio from the tv to the entertainment center- thereby letting the tv put sound out of the ceiling speakers and the ones on the tv.   Now I can hear it.
If doing this one also has to change the input source on the entertainment center to have sound amplified by it on the way to the ceiling speakers....at least mine are in the ceiling.
2014 179
Posted By: ANGCHIEF
Date Posted: 24 May 2014 at 12:18pm
Still no DVD picture - everything looks hooked up right, no dangling wires. Turn on the TV, Select COMPONENT as the source, insert the DVD and select DVD on the radio/DVD player mounted on the wall. Get the blue Jensen screen, the Radio screen says loading, then I get DISC ERR and the radio flips back on. I have tried 3 different DVD's with the same problem. I even pulled up the abbreviated manual with no success.
So frustrating! We are leaving on an extended trip and would really like to have the DVD to play as we kick back to relax at night when there is nothing on TV and it's rainy out.
HELP!!!
Jan and Dean
2014 178
Date Posted: 24 May 2014 at 1:21pm
Unless you are using components cables, red/green/blue, you will not be selecting the component input. What color are the cable plugs you have?
2014 rpod 182G
Ford Expedition
Posted By: ANGCHIEF
Date Posted: 24 May 2014 at 1:29pm
Just the yellow running from the wall to the TV
So frustrating!!!!   Thanks in advance for your help!
Jan and Dean
2014 178
Posted By: Scoul
Date Posted: 24 May 2014 at 4:15pm
Does your wall mount look like this?
If it does than hook your cables as follows.
And the tv end.
Then put in a DVD and select the input that plays the video. Remember blu ray doesn't work.
"Anyone can hold the helm when the sea is calm." Publilius Syrus
2015 GMC 1500
2014 182g
2009 Harley FXSTB
Posted By: ANGCHIEF
Date Posted: 24 May 2014 at 5:16pm
No - this is what mine looks like - just 1 input from wall
uploads/2332/Pod_TV_connections.jpg - uploads/2332/Pod_TV_connections.jpg
uploads/2332/Pod_TV_Wall_connections.jpg - uploads/2332/Pod_TV_Wall_connections.jpg
Jan and Dean
2014 178
Posted By: Scoul
Date Posted: 25 May 2014 at 1:59am
Sorry buddy guess I'm no help, I'd call forest river and see what they say.
2015 GMC 1500
2014 182g
2009 Harley FXSTB
Posted By: Budward
Date Posted: 25 May 2014 at 4:25am
I'd pull the entertainment center (easy 4 screws) and make sure the connections on it are plugged in and the video cable is plugged to the backside of that wall plate jack.
If that is all good-  do you have another video source you could try to confirm input on tv is good?   Maybe a camcorder?
If that works then see if video out on tv is good by plugging in to another tv or monitor..
2014 179
Posted By: ANGCHIEF
Date Posted: 25 May 2014 at 8:48am
I think calling Forest River is a good idea.  The TV works fine and the radio is great - just can't get that pesky DVD player part of it to work.  I really appreciate all your input from you guys and taking your time to help me out.  I'll post what I find out.  Have a wonderful Memorial Day and from Dean and I (both Veterans) to all our Veterans we appreciate your service.  Special nod to all the retired policemen and firefighters out there, also.  See you on the road!
Jan and Dean
2014 178
Date Posted: 25 May 2014 at 11:01am
Yeah, I can't help you either. Ours has the black wall plate with multiple cables. Our '14 178 has the "Crown Package" with the outdoor speakers, etc. Does yours?
2014 RP178
Posted By: ANGCHIEF
Date Posted: 25 May 2014 at 11:31am
Yes; we have the outdoor speakers, also - I'll let you know what I find out from Forest River on Tuesday.  Thanks for your help.
Jan and Dean
2014 178
Posted By: Cap-n-Cray
Date Posted: 25 May 2014 at 2:40pm
Jan or Dean,
My 2014 177 has three cables going to the TV from the wall; red, white, and yellow. They are hooked up to the input on the TV. My DVD plays on AV. My wall plug has the three connectors too, not just one. You might take the TV Video wall plate off and see if there are other wires behind it. Maybe they installed the wrong plate?
The DVD sound comes from the system speakers. I have had problems with the USB memory plug not loading.
Cary
2014 RP-177
Posted By: Diwill
Date Posted: 25 May 2014 at 5:17pm
I have a 2014 Jensen system. There is just a yellow cable to connect. I connects on the wall to the TV video out and to the yellow jack on the back of the TV, then change the TV source to AV by pressing the source button on the TV or on the remote.  If it still doesn't work, there must be a problem in the system and you should contact the dealer.
Posted By: ANGCHIEF
Date Posted: 26 May 2014 at 8:25pm
Does anyone know the phone number for Forest River so I can call them?
Jan and Dean
2014 178
Date Posted: 26 May 2014 at 8:31pm
http://www.rpod-owners.com/forum_posts.asp?TID=2747&title=misc-forest-river-contacts-and-other-info - http://www.rpod-owners.com/forum_posts.asp?TID=2747&title=misc-forest-river-contacts-and-other-info
Cary
2014 RP-177
Posted By: ANGCHIEF
Date Posted: 27 May 2014 at 9:24pm
GOOD NEWS GOOD NEWS!!! I finally took the unit out and checked the back for the transportscrew.  There were a bunch of numbered/lettered wires not hooked to anything, but were sticking in the vents in the back of the DVD area.  Verified that transport screw had been removed.  We carefully moved all the wires to the side and out of the vents & carefully reinstalled the unit.
Bingo!!!  DVD plays as advertised!  I think the ends of those wires were preventing the Disc from playing.  Or else we scared the unit because now it knows we can remove it's guts!!!
Thanks for all your help!  This forum is the greatest!!!
Jan and Dean
2014 178
Posted By: Markus5
Date Posted: 01 Jun 2014 at 8:19pm
We have the same problem with our new 177. No dvd. Can't remove the base unit. It is attached with square drive screws. Boo. I don’t have anything like that here. I'll bring something later.
Posted By: Markus5
Date Posted: 01 Jun 2014 at 8:23pm
And there aren't many tv channels here. Other folks get more. I have the booster on and it's red. The one channel and it's 3 subchannels are good. Should be more. Does the antenna on a 177 adjust in any way?
Posted By: ANGCHIEF
Date Posted: 01 Jun 2014 at 8:28pm
Can't adjust the antennae like we can on our 5th wheel; did the Auto Search with the boost on and you get what you can get! That's one of the reasons we like to take DVD's of some interesting TV shows.  This trip is JAG and DOWNTON ABBY Season 1 (even though we've seen all the episodes).
Luckily my husband had a bit that worked to get the square screws out - pulled the dangling wires out of the vents in the back, put the unit back and the DVD played great.
Good luck!  Isn't it frustrating???!!!
Jan and Dean
2014 178
Posted By: Markus5
Date Posted: 01 Jun 2014 at 8:43pm
I hope I have the same good luck.
Date Posted: 01 Jun 2014 at 11:15pm
Look closer at the screws. They aren't square, they're stripped. We had the problem with ours. Forest River said the screws get stripped a lot.
2014 rpod 182G
Ford Expedition
Date Posted: 01 Jun 2014 at 11:26pm
Most of the screws used in my Rpod are square drive. I even found a square drive bit behind the frig. Sometimes you can use a small phillips screwdriver to remove the square drive screws.
With the speed them put the trailers together they do strip the screws too.
Cary
2014 RP-177
Posted By: ANGCHIEF
Date Posted: 02 Jun 2014 at 8:01am
Ours were definitely a square screw.  Luckily hubby had a square drive bit or ours would have been stripped screws, also!
Jan and Dean
2014 178
Posted By: Sleepless
Date Posted: 19 Jun 2014 at 8:31pm
Let me run this by one more time, just to b certain my thinking is correct.  My 2014 178 has but one cable, a yellow video, running between the single-cable wall jack to the television.  This cable is for the sole purpose of viewing a DVD video (picture) on the television.  Audio will be through the Jensen speakers (A or B), but not through the television.
To hear television audio through the Jensen speakers, I must install another wall jack and run audio (red and white) cables, using the new jack, between the Jensen radio's audio in jacks and the television's audio out jacks.
An alternative is to install an A/V (red, white and yellow) wall jack, replacing the existing yellow only jack.  The yellow (video) jack will connect the DVD player video out jack to the television's video in jack.  The red and white (audio) jacks will connect the television's audio out jacks to the radio's audio in jack.
Either setup will allow watching a DVD on the television using the Jensen speaker system(s).  They will also allow hearing the television's audio on the Jensen speaker system(s).
Have I overlooked anything?  I have read all the posts related to this problem, but a clear presentation of the resolution does not seem to exist.
Bob
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Posted By: fwunder
Date Posted: 19 Jun 2014 at 9:04pm
Seems every dealer may offer different TV options, but on mine I can simply run a RCA to mini cable from audio out on TV to AV in on Jensen Head unit. Put the Jensen in AUX mode and I'm good to go.
Does that make sense?
Date Posted: 19 Jun 2014 at 9:33pm
Fred, you and I bought our 178s about the same time with delivery sometime in November, if I remember correctly.  Assuming your pod came with a single yellow video cable between the TV's video in and the Jensen (head's) video out, they came set up identically.  That is fine for viewing DVDs on the TV.
All I was trying to tell is that to hear the TV audio through the Jensen (head), I must run audio cables between the audio outputs on the TV to the audio input on the Jensen (head).  This can be achieved by either of the two alternatives I gave.
I believe you and I are saying the same thing, or are we?  Sometimes my "simple" approach becomes more complicated than it need be.  I value comments from podders like you that have resolved the problem.
Bob
Posted By: fwunder
Date Posted: 19 Jun 2014 at 9:43pm
Bob,
I'm sure we're talking the same animal. This is what I use:
Date Posted: 19 Jun 2014 at 10:04pm
That will do it!  Thanks, Fred.
Bob
Posted By: ToddLat
Date Posted: 20 Jun 2014 at 1:53pm
We have a 2013 unit and it has an aux in (3.5mm) on the face plate.  We connect a 3.5mm male-male to the headphone out of our tv directly to the aux in on the face plate.  put the jensen on aux 2 and off we go.
Todd and Beth
2013 RP 176 T
2013 Nissan Pathfinder
Posted By: fwunder
Date Posted: 20 Jun 2014 at 2:04pm
Yep Todd, that'll work too. I just didn't happen to have a male mini-mini so I used what I had in my box 'O wires. Of course, we all should be outside instead of inside watchin TV! Wink
Posted By: ToddLat
Date Posted: 20 Jun 2014 at 2:15pm
Very true Fred!  It does help though on those days with the sun is not so shiney and the pod is the only dry place in town!  Well, dry in the sense that its not wet!  The cooler is always full of the good stuff!
Todd
Todd and Beth
2013 RP 176 T
Posted By: TriumphRider
Date Posted: 20 Jun 2014 at 8:02pm
Ouch I tried using the RCA to 3.5mm? mini connector from the audio-out ports on the TV to the audio in on the Jensen, but still did not get the TV sound from the sound system speakers.
Looking at the menu options on the TV there is an option to enable the audio-out, but on my TV that option is grayed out.
For those of you that have made this work, did you have to enable the audio out from the TV?
TriumphRider
Posted By: fwunder
Date Posted: 20 Jun 2014 at 8:12pm
Hi TR,
If somebody doesn't beat me to it, I'll try to snap some pics how it work's on my unit tomorrow evening we we arrive we're we're going.
Yes, there is a TV menu option to choose audio output, but I don't recall right now. Also, of course, you need to have the Jensen stereo set to AUX. If using the headphone jack and AV input on Jensen stereo, you don't have to make any TV menu changes.
Date Posted: 20 Jun 2014 at 8:44pm
I copied Fred's hook-up and did not have to use the menu options.
Posted By: fwunder
Date Posted: 20 Jun 2014 at 8:50pm
That's cuz you're special Bob. Wink
I thought there is a menu option to change audio output, but may not be. Got too much AV stuff in the house. I'll check the pod tomorrow. Right now, priority is getting fridge cold and packed for a quick weekender. BTW, I don't travel with the TV on it's mount. It travels screen down on the bed otherwise I would have a looksee right now.
Posted By: GingerPod
Date Posted: 27 Aug 2014 at 8:41pm
TriumphRider
This is what my TV does......why does it seem everyone's' entertainment components are different?
All I want is to hear the TV through the Jenson speakers....LOL
FOUND OUR NEW-RETRO TEARDROP!!!
Posted By: ToddLat
Date Posted: 27 Aug 2014 at 9:12pm
We use the headphone out on our tv to the 3.5 mm input on the Jensen. Works great for us
Todd
Todd and Beth
2013 RP 176 T
Date Posted: 27 Aug 2014 at 9:20pm
Todd
Cool,I tried that method as well but no go.....
With the TV output audio "grayed out" in the Menu,there is no output for speaker sound to exit the TV to got to the head unit.
Just seems stupid the FR would supply some Pods with TV's that can be made to work with the Jenson speakers while watching TV and some that won't work.
The TV output audio is the ONLY menu option that is grayed out in ALL 5 categories ...Ouch
