Remote Propane line
URL: http://www.rpod-owners.com/forum_posts.asp?TID=4671
Printed Date: 19 Aug 2025 at 9:45am
Topic: Remote Propane line
Posted By: Hairy Podders
Subject: Remote Propane line
Date Posted: 02 May 2014 at 6:52am
We have a Coleman Roadtrip LXE portable grill that we use when camping that uses 1 lb. bottles. I bought a remote hose kit for it & a quick disconnect coupler from Camping World. I am going to tee into the existing gas line. My question is this: do you tee into the gas line before or after the regulator on the camper?
Darryl, Julie & Lindsey
2014 RP178
Posted By: kymooses
Date Posted: 02 May 2014 at 10:15am
you'd have to do it before the regulator since your grill has it's own regulator on it.
do you have a G model?
Date Posted: 02 May 2014 at 12:21pm
Thats what I thought. But didn't know for sure. We have a '14 178.
2014 RP178
Posted By: kymooses
Date Posted: 04 May 2014 at 6:38pm
there is a good mod video on youtube for modifying the coleman grills to remove their regulator that way you could put the connection wherever you wanted.
not sure if you're interested in going that far with it but i'll dig it up if you are.
Date Posted: 04 May 2014 at 10:59pm
Travis, I figured out my routing & have it roughed in. I just need to seal everything up & final tighten everything. It should be pretty nice when finished.
Thanks for the offer though. If this doesn't work out, I'll be hitting you up for that info.
Thanks again!
2014 RP178
Posted By: kymooses
Date Posted: 05 May 2014 at 9:53am
absolutely!
eager to see and hear about it once you're all set up.
