Spare tire carrier idea
URL: http://www.rpod-owners.com/forum_posts.asp?TID=4466
Printed Date: 19 Aug 2025 at 2:27am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Spare tire carrier idea
Posted By: Hairy Podders
Subject: Spare tire carrier idea
Date Posted: 09 Mar 2014 at 1:45pm
Has anyone looked at using a spare tire carrier winch type setup from a pickup truck under the back of their pod? I realize that some type of crossmember would probably have to be mounted to the pod frame.
I have been brainstorming on how to free up the space for the bike rack & still carry the spare cleanly. Plus looking at the structure that holds the spare tire/bike rack kinda scares me. I'm gonna have to brace that a bit for peace of mind.
------------- Darryl, Julie & Lindsey
2014 RP178
Posted By: furpod
Date Posted: 09 Mar 2014 at 2:06pm
It's been done (more or less) under the tongue. Airstreams carry their spare under the front of the trailer, on ours its on the street side, may be enough room on the pod to do something similar.On our 177, there is room under the front center area to pull or lock a spare up into, forward of the black tank. The 'stream doesn't winch up like a truck, but has a lifting rack sort of deal, its not ideal for getting the spare on and off, but it does store it out of the way, and just about as high as possible, where, hopefully it never has to be used from..lol.
Date Posted: 09 Mar 2014 at 6:49pm
After giving the pods a quick peek under the back, I think the spare will fit between the framerails, forward of the hitch where the bike rack (and spare now) mounts. I want to get the tire as high as possible for ground clearance. Plus I want it out of the way. After we pick our 178 up on the 22nd, that is going to be my first mod. Like Jeeps(which we have 4) you can never leave well enough alone.
2014 RP178
Posted By: furpod
Date Posted: 09 Mar 2014 at 8:41pm
You are going to make a fine podmodder.
Posted By: wingnut2312
Date Posted: 10 Mar 2014 at 9:39am
We attached the spare to the tongue. There was a thread on here that showed it. Have to get an extender so there is room for dual battery and dual propane tank (if you have that). Works well, but I would get a cover for the tire.
------------- 2014 rpod 182G
Ford Expedition
Posted By: techntrek
Date Posted: 10 Mar 2014 at 6:18pm
Sounds like a cool idea.
