Fan on A/C
URL: http://www.rpod-owners.com/forum_posts.asp?TID=3965
Printed Date: 18 Aug 2025 at 1:19pm
Topic: Fan on A/C
Posted By: P&M
Subject: Fan on A/C
Date Posted: 10 Sep 2013 at 7:02pm
Just a question since I don't know ... does everyone else have the fan constantly running when the A/C is set, even when the "cooling" mode is not running? I mean, you can hear the A/C kick on with the refrigerant cooling and cold air pumping out, but when it reaches temp and the A/C shuts off the fan keeps running 100% of the time until the next A/C cooling cycle. So the fan never actually shuts off unless I actually turn the A/C off at the thermostat.
Since my house A/C doesn't work this way I am curious if my Pod A/C is supposed to ... thanks.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
Posted By: furpod
Date Posted: 10 Sep 2013 at 7:04pm
if you have your fan setting to "on" that is what it will do. Set the fan control to "Auto" or "AU" if you have the digital thermostat, and it will only run the fan when cooling is called for.
Many people just run it in the on mode, so there is less instant loud noise when the a/c cycles..
Posted By: P&M
Date Posted: 11 Sep 2013 at 11:09am
thanks furpod!
2018 Ram 2500
