Slide out
Forum Name: Miscellaneous / Off-topic
Forum Discription: Pull a chair up to the campfire and chat. No religious, political or weapons talk, please.
URL: http://www.rpod-owners.com/forum_posts.asp?TID=3651
Printed Date: 21 Jul 2025 at 8:44am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Slide out
Posted By: Newbie
Subject: Slide out
Date Posted: 24 Jun 2013 at 7:18pm
We have the rp177 , is there any way to manually put slide in if for some reason you were to lose power.
------------- Rp177
2013 grand caravan
Posted By: Keith-N-Dar
Date Posted: 24 Jun 2013 at 9:24pm
If you remove the panel on the inside of the pod at the bottom of the slide I am told there is a nut you can put the wrench for the stabilizer jacks on to run the slide in or out without poer. I have never tried it.
------------- Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: furpod
Date Posted: 24 Jun 2013 at 9:45pm
Yes. Just as Keith-n-Dar said. Right hand bottom panel. The nut is the same size as your stabilizer jack handle...
Never done it on a/the Pod.. but HAVE cranked a slide in once. A skill I don't intend to perfect.
the smart thing to do if you lose power is hook up your tow vehicle..
Posted By: Newbie
Date Posted: 24 Jun 2013 at 9:49pm
Thank you
------------- Rp177
2013 grand caravan
Posted By: Seanl
Date Posted: 25 Jun 2013 at 8:45am
I would suggest an 18 volt drill or impact wrench with a 3/4 inch socket on it to run the slide in if it stops working for any reason. I use one to run my stabilizer jacks up and down. Yes I am lazy and getting old.
------------- Sean, 2011 Rpod RP-173,2009 Jeep Liberty Rocky Mountain Edition
Posted By: hogone
Date Posted: 25 Jun 2013 at 8:48am
One note: Hooking up to the TV will only help if you have the charging system from the TV activated and/or available
------------- Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted By: Newbie
Date Posted: 25 Jun 2013 at 9:28am
Ya I got tht activated so would work TyTy
------------- Rp177
2013 grand caravan
Posted By: furpod
Date Posted: 25 Jun 2013 at 9:38am
Originally posted by hogone
One note: Hooking up to the TV will only help if you have the charging system from the TV activated and/or available |
jumper cables man, jumper cables. No truck should be without a set. You can move way more power through them in a short time than through the "charging cable" of the TV.
Posted By: hogone
Date Posted: 25 Jun 2013 at 10:01am
Oh, jumper cables. Sure, that would work too!!! Your right, that would be much more efficient. Thanks for setting me straight!!!! I will be honest, I do not have a pair in my truck. Thet will be in there tonight however.
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted By: techntrek
Date Posted: 25 Jun 2013 at 8:48pm
jumper cables, a pair of pliers, quality 12 volt air pump, and a tire plug repair kit.
