Leak at window
Forum Name: Warranty, Service and Recall Bulletins
Forum Discription: Have a warranty or service experience to share?
URL: http://www.rpod-owners.com/forum_posts.asp?TID=3025
Printed Date: 06 Aug 2025 at 5:14pm
Topic: Leak at window
Posted By: camper4ever
Subject: Leak at window
Date Posted: 14 Oct 2012 at 5:33pm
We have not taken the Pod out on many trips this summer, but Autumn is our favorite time to camp.  I noticed some staining running down the wall below the rear drivers side window.  On closer inspection, it appears that there has been some water leaking.  The wall has some bubbling and a number of small sharp bumps.  I checked the outside seal as well as the seal along the roof and can find no place where water is clearly leaking.  Any ideas?Ouch
2010 173T
2007 Toyota Highlander
Posted By: Seanl
Date Posted: 15 Oct 2012 at 7:47am
Check to make sure that the drain holes on the window are open If they get plugged then water will run inside instead out out the drains.
Date Posted: 20 Oct 2012 at 12:59pm
I checked the drain holes and they are clear.  It is the emergency exit window, so I popped it open and the inside of the frame is clean and does not appear that water was in there.  It looks like the water is coming from under the window frame.  We are thinking about caulking around the outside of the window.
2010 173T
