Hot Water Heater Anode Replacement
URL: http://www.rpod-owners.com/forum_posts.asp?TID=2851
Printed Date: 15 Aug 2025 at 8:10am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Hot Water Heater Anode Replacement
Posted By: Footslogger03
Subject: Hot Water Heater Anode Replacement
Date Posted: 21 Aug 2012 at 10:58am
For those of you who have replaced the anode in their Suburban Hot Water Heater ...did you get the OEM Suburban part (#232767) for around $15 or the Camco one (#11691) for around $9. I guess the big questions are ...are they equivalent AND will using the Camco model void the warranty ?
Thanks in advance,
'Slogger
------------- Livin' the Dream ...'Slogger
Posted By: Seanl
Date Posted: 21 Aug 2012 at 11:51am
I think maybe the part number for the Camco rod is wrong I get a water tank rinser for that part number. I don't think it makes a lot of difference but I would get a magnesium rod not an aluminum one. Magnesium works better and is not as toxic as aluminum. Also Magnesium will not cause as much sediment to build up in the tank.
------------- Sean, 2011 Rpod RP-173,2009 Jeep Liberty Rocky Mountain Edition
Date Posted: 21 Aug 2012 at 11:54am
Originally posted by Seanl
I think maybe the part number for the Camco rod is wrong I get a water tank rinser for that part number. I don't think it makes a lot of difference but I would get a magnesium rod not an aluminum one. Magnesium works better and is not as toxic as aluminum. Also Magnesium will not cause as much sediment to build up in the tank. |
You're correct ...I had multiple window up on Amazon and grabbed the wrong Camco part #. As for the Aluminum versus Magnesium tip - - thanks a lot. I didn't pick up on that when I was reviewing the on-line replacement choices.
'Slogger
Date Posted: 21 Aug 2012 at 12:04pm
Seanl ...if you don't mind me asking - - where do you get your magnesium replacement anodes ? I've been doing some searching and the vast majority of anodes for sale are of the aluminum variety. I found a couple magnesium ones but they don't look compatible with the Suburban hot water heater in my Pod.
'Slogger
