Black tank dumping
URL: http://www.rpod-owners.com/forum_posts.asp?TID=2774
Printed Date: 15 Aug 2025 at 8:14am Software Version: Web Wiz Forums 9.64 - http://www.webwizforums.com
Topic: Black tank dumping
Posted By: Cmtpod
Subject: Black tank dumping
Date Posted: 25 Jul 2012 at 7:34pm
Ok oh wise ones, newby with a question. 1st trip planned in the pod this weekend, first camping trip with indoor plumbing, this 182g is one heck of a step forward from my 15 yr old pop-up. Anyway, when do you dump the tanks, ie do you always dump them prior to leaving a campground? I see people saying wait until the black tank is 2/3 or 3/4 full, but i doubt we'll fill it up that much in a weekend. On the other hand I'm not sure I want that crap (pun intended) sitting around for a few weeks until the next trip. Thanks in advance for all the great advice!
Posted By: Podsible Dream
Date Posted: 25 Jul 2012 at 8:08pm
We dump on the way out...no sense worrying bout what might be emitted from tha tank! It also lightens the load for the trip home... Eight pounds a gallon adds up quick!
------------- Chris and Walt
'10 RP-171 'Free Spirit'
Posted By: dsmiths
Date Posted: 25 Jul 2012 at 8:23pm
I am with podsible, one of our favorite spots close to home has a dump station about 3 miles from the camp, this kind of jostles the junk around in the trunk, hook up dump hose, open black water first and when its done gurgling and is done close black water valve and open the grey, this will help rinse the hose out. then rinse the hose out with fresh water if avalable. trust me you dont want that stuff laying in the black tank for a week or so in this heat. yuck.
------------- Dane and Donna Smith
2011 RP-172
lift kit
Posted By: KDHfan
Date Posted: 25 Jul 2012 at 9:36pm
First... I would suggest a new Rhino sewer hose.. the one that came with our 182G isn't the best. The black tank doesn't fill very quick (we normally use the campground bathrooms except at night)... but the grey tank filled very quickly... contrary to what our RV dealer told us, the garage sink dumps into the grey tank too. We dump the tanks just before we leave... black tank first until it stops running... If we're only 1/3 full or less, we attach a water hose to the hook-up beside the entry door to clean out the toilet (make sure you leave the black tank OPEN with dump lines hooked up). Then we disconnect and move the line over to dump the grey tanks. I'm a newbie at this too... but i don't think it would be wise to leave "stuff" in the black tank for an extended period.
------------- Mark, Beth, Nolan & Madeline
2012 182G... "NoMad"
TV - 2012 Nissan Armada
SB/WDB
Posted By: dsmiths
Date Posted: 25 Jul 2012 at 9:42pm
KDHfan is on track, I got the rhino 15 foot collapsable model, reasonably priced. I goggled the name on the end of my drain hose holder that used to be on the front of the pod under the battery. Called the people, they were very nice a larger tube that holds the rhino was like 18 bucks plus shipping. I moved the larger tube back, it fit between the old tube and the black water drain valve, works perfect. you can't see the holder, I have a longer stronger hose at a very reasonable price. no pun intended.
2011 RP-172
lift kit
Posted By: Iteach5th
Date Posted: 25 Jul 2012 at 10:51pm
I dump mine when about 3/4 full. Gotta get risers soon. Tired of playing with the slinky to empty the tank.
------------- "Whether you think you can or think you can't, either way you are right"- Henry Ford
2011 RP-177
2009 Jeep Cherokee
1982 Coleman Redwood pup
Posted By: furpod
Date Posted: 26 Jul 2012 at 8:22am
We will gennerally wait until 3/4 to dump, even if it takes a couple outings. Never a problem with.. build up.
Unless I think it's the last camp of the year, then we make sure we are 3/4 before breaking camp.. just "top it off" with the flush handle, drive to dump station..
Posted By: kymooses
Date Posted: 26 Jul 2012 at 9:28am
We dump every single trip, even if it was just a weekend getaway. We'll run the water to fill the tank up and empty both out and prep for next time. Originally the reasoning was that I didn't want the extra weight sloshing around. However now that I'm not concerned about that as much I guess it's just become habit. Are we the only "every trip" dumpers?
------------- https://calendar.google.com/calendar?cid=cnBvZC5zcG90dGVyQGdtYWlsLmNvbQ - RPod Rallies
Posted By: Camper Bob
Date Posted: 26 Jul 2012 at 10:28am
Nah. I also dump the black tank at the end of each trip, no matter how long, or short. However, we do also have the rinse attachment that was factory installed. I close the grey water gate, fill the black water tank and when it shows nearly full, I open the black water gate, and let it continue to "flush" until all runs clear. Safe Travels.
------------- Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Posted By: KDHfan
Date Posted: 26 Jul 2012 at 12:05pm
So far, we've dumped each outing. I can't ever foresee us not dumping each trip.
SB/WDB
Posted By: poder
Date Posted: 26 Jul 2012 at 3:55pm
We empty every time and rinse. Once in a while, I will but a bag or 2 of ice in the tank and a cup of soap for on the way home. The ice will slide around and scrape off any thing that may stick to to bottom on the tank like paper etc. Before anyone ask how you get the ice out?. it melts. I know we are all smart here but someone all ways ask me that.
Thanks
Posted By: barbanjoe
Date Posted: 26 Jul 2012 at 11:13pm
We dump every trip, pour a small bottle of blue stuff and add water with 2 flushes. The Big bottle is inexpensive at Walmart and I refill smaller bottles. But, like most of the campers I know and have met, It is easier to use campgrounds facilities for # 2 and you don"t have all that work to deal with,after all camping Is about relaxing!
------------- BarbanJoe
010 Rpod 171
02 Jeep 4x4
12 Ram 1500
Posted By: techntrek
Date Posted: 30 Jul 2012 at 3:38pm
The 3/4 full recommendation is to ensure you get enough pressure/movement as the tank empties to move the solids out. If you are not that full at the end of the trip but want to dump, first fill up the black tank by holding the toilet flush valve.
Also make sure you dump the black tank first, then dump the gray tank. That will flush out the hose. You should never leave the black tank open if you have full hookups, but you can leave the gray tank open until just before you dump the black tank. Close it to get 2-3 showers worth of water in it, then you can dump the black tank and then the gray tank.
Posted By: JimboG
Date Posted: 30 Jul 2012 at 5:49pm
A little tip. I went to a dump station that had the driveway tilited a little toward the drain in the ground. The problem is the drain on the tank is in the middle of my 177 so it didn't do a good job of draining it. Next time I will find a dump station on level ground.
