lp detector
URL: http://www.rpod-owners.com/forum_posts.asp?TID=2564
Printed Date: 16 Aug 2025 at 7:55am
Topic: lp detector
Posted By: blissful
Subject: lp detector
Date Posted: 13 May 2012 at 2:08pm
Me, again.  Seems that things are not going well for my one year old 171.  The lp detector is bad and has to be replaced.  Does anyone know about a better, less sensitive model that does not go off after a sneeze?
Blissful
Posted By: techntrek
Date Posted: 13 May 2012 at 9:03pm
Are you sure the detector is bad?  The pod is a very tight airspace and we've found sprays - and fumes from the toilet if its valve is left open too long - will set it off.  If you do need a new one I would just search online for a new one.
Posted By: secretbard
Date Posted: 14 May 2012 at 7:08am
Mist will set it off.  I had some sputter and mist push out of my sink before a straight flow of water would occur and that mist set off the propane detector and it would not shut off until I opened the bathroom vent fan and circulated air throughout the cabin.  Yes, the detector scared me too.  I thought I had a leak somewhere, then put two and two together and figured out that it was the mist.
2010 Rpod 172   :)
2004 Chevy Trailblazer
Posted By: Keith-N-Dar
Date Posted: 14 May 2012 at 9:50am
The only time mine went off was with a low battery.  When I charged it up the detector no longer went off.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Posted By: blissful
Date Posted: 14 May 2012 at 12:17pm
I have ordered a more substantial detector that is less sensative to hair spray, mist, etc.  Sure hope it's worth the price.  While I am at it, how do you get those small plastic caps that the wires connect to off when I install new detector?
Blissful
Posted By: blissful
Date Posted: 14 May 2012 at 12:19pm
Battery O.K.
I was once told that a fluctuation in power while camping will set it off.  Mine definitely is bad.....no red light, etc.
Date Posted: 14 May 2012 at 1:52pm
Sorry, I've never removed mine so I can't help you with the tabs.
