Water valve shut-off question...
URL: http://www.rpod-owners.com/forum_posts.asp?TID=1861
Printed Date: 06 Aug 2025 at 9:40pm
Topic: Water valve shut-off question...
Posted By: secretbard
Subject: Water valve shut-off question...
Date Posted: 05 Jun 2011 at 8:35pm
Underneath my right dinette seat, there is what looks like the water pump and PVC piping.  There are three shut-off valves on the PVC piping and I believe I have them all turned so that they are all horizontal... none perpendicular.  My question is, is this right, and what do all these shut-off valves shut off or turn on?  As I understand it, one of them is for the hot water, the other for the cold water, and the final one is for all the water.  Am I correct?  I'd like to mark them to tell me which is which and I'd also like to know what is the proper open and shut off for both in-use and winterization.
Are there any illustrated pictures on this site that show what these pipes are and how to set the valves?
Thanks.
2010 Rpod 172   :)
2004 Chevy Trailblazer
Posted By: techntrek
Date Posted: 05 Jun 2011 at 10:04pm
Are the pipes and valves right behind your water heater?
Posted By: Outbound
Date Posted: 05 Jun 2011 at 10:30pm
You've found the bypass valves for your water heater.
For summer operation: the middle valve, on the short length of hose between the other two valves, should be set perpendicular.  The other two valves should be set parallel with the hose.
Date Posted: 06 Jun 2011 at 1:15am
Yes, they are in front of the water heater.  Thanks Outbound, I think you helped me figure out what settings are correct for this time of year.
2010 Rpod 172   :)
Posted By: Hodge-PODge
Date Posted: 06 Jun 2011 at 10:32am
Originally posted by secretbard
Underneath my right dinette seat, there is what looks like the water pump and PVC piping.  There are three shut-off valves on the PVC piping . . . . .
Oh Lordy!  Mountain Mist and I are bound to be so jealous!  Your valves are so ACCESSIBLE compared to the ones in our R-Pods -- as our very LONG hilarious discussion in another forum can attest.  We have to crawl under the dang bed after figuring out how to prop the mattress up.  And we had lots of help in the forum figuring that one out!
I'm green with envy -- your access is so SIMPLE (but maybe not as much fun LOL).
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
